Drivetrain Reaching target boost pressure
Old Apr 20, 2023 | 11:06 AM
Benoito's Avatar
Benoito
Hi everyone
I've got a Manic Stage 2 tune to my Mini, which should let the engine operate with up to 22-24 PSI of boost, when full throttle.
However, I just reach the standard 14-15 PSI of a Cooper S.
I run a:
JCW turbo
GFB valve
Wagner intercooler
Do you have any ideas why I'm not reaching the figures?
The tuner told me to read out the "target boost". How is this different from what they have changed in the ECU?
Old Apr 20, 2023 | 12:30 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I feel sorry for you if you just had a Manic tune loaded. Manic went out of the tuning business maybe 3-4 years ago.
That being said, the Manic tunes have the ability to switch performance maps. Its possible your car is still on the OEM map. Using the SPS switch, you have the ability to select up to 3 different tune operations.
Here is one listed in the marketplace for reference:
https://www.northamericanmotoring.co...?highlight=sps
Old Apr 20, 2023 | 12:48 PM
Benoito's Avatar
Benoito
Thanks for your response.
I wasn't specific enough with my statement.
I had the tune done from the guy, who used to do the Manic tunes in England.
I've send my ECU there.
Old Apr 20, 2023 | 03:06 PM
cooper48's Avatar
cooper48
24 lbs. of boost won't turn your engine into a grenade?
Old Apr 21, 2023 | 05:03 PM
yesti's Avatar
yesti
Stage 2 requires an aftermarket downpipe, do you have that in the works? Did you change to NGK 1422 spark plugs? Do you have the SPS switch? How are you reading boost? Target boost most likely depends on load so it may not match the full boost spec of the tune.
E34M5
Jul 16, 2018 05:50 PM
keithmcgreggor
Nov 30, 2017 03:33 PM
freestylin599
Jul 29, 2015 08:54 AM
scottab36
Mar 10, 2011 05:31 PM
Coen_de_K
Sep 6, 2009 02:24 PM
