Drivetrain Conversion to Cooper GT
Old Nov 20, 2022 | 01:53 AM
Chocolate R55's Avatar
Chocolate R55
Hi All,
New member. I have a 2008 mini clubman cooper r55.
I need a new exhaust from downpipe back.
I have bought a stainless steel 2.5 inch (63mm) bore cooper s exhaust with the 2 exhaust pipes on either side of the rear of the car.
i am planning to fit this to my cooper. It is easy to adapt for second exhaust exit as hanger bolts already in situ and can reuse hangers from large standard muffler box and will cut the black lower rear skirt to accommodate..
I have jacked the car up and found the 2.5 inch manifold flange on the new cooper s exhaust is larger in diameter than the cooper (I'd say 2.5 inchs to 2 inchs) downpipe and hence the 2 do not mate up.
Seems the solution is to change the downpipe from a cooper to cooper s. I need to retain the cat for mot tests.
Welcome anyones thoughts?
Old Nov 20, 2022 | 04:40 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Keep the OEM exhaust to just past the engine/ subframe, then cut and fit an exhaust reducer coupling between the OEM and the S exhaust.
just need something like this:
Chocolate R55
R55 :: Clubman Talk (2008+)
Jan 9, 2023 01:47 PM
///Matthew
PhillyMINI Club
Feb 10, 2021 05:55 AM
///Matthew
Feb 10, 2021 02:01 AM
Kupona
Mar 17, 2020 01:50 PM
