Drivetrain M Factory LSD issues
Old Jan 29, 2021 | 10:41 AM
Massimo Lucidi's Avatar
Massimo Lucidi
Hello all,
I purchased an M Factory LSD for my Mini Cooper S, and have had the driver side axle keep popping out of the M Factory Diff. It’s a helical LSD, does anyone else run an the diff and have the same issue? I am in the process of rebuilding the engine, and am trying to justify if I need another LSD that would work. Please let me know, thank you!
Old Jan 29, 2021 | 11:35 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Curious, as I have an MFactory diff waiting to go into my gearbox... Are you sure the axel clip is fully seating? Was it replaced when swapping out the diff?
Old Jan 30, 2021 | 12:12 AM
OCR's Avatar
OCR
What I'd like to know is -
EVERYTHING has manufacturing tolerances. I'll be installing a new limited slip differential in my JCW next spring (after the rains end). The factory unit is broken.
I see no side to side adjustments anywhere in the case. If the new limited slip unit is a little long, it'll burn up the carrier bearings from too much side load. If it's a little short, it be sloppy loose, and again, tear up the bearings.
Am I missing something ?
Mike
Old Jan 30, 2021 | 09:25 AM
scottyb043's Avatar
scottyb043
Do they not make shim packs for adjusting the carrier bearing preload? Normally this is part of setting up a diff in order to get a good pattern and bearing preload.
Old Jan 30, 2021 | 12:44 PM
OCR's Avatar
OCR
Scott -
No...
The Mini drive gears are not...of the crown gear design. They are a spur gear design.
So in fact, the gear mesh can be a little off, side to side without harm. The tooth mesh is not affected by side to side location.
BUT, the "length" of the differential (bearing location) is as it sits in the trans-axle case.
So again, how is it measured and adjusted to attain the proper bearing preload.
Mike
Old Jan 30, 2021 | 04:42 PM
cmt52663's Avatar
cmt52663
Here's an axle story that I was reminded of by your difficulties.
Cheers,
Charlie
Old Jan 30, 2021 | 08:49 PM
OCR's Avatar
OCR
As I commented in the thread above...
What looks to be about .25" of spline engagement, is pretty weak. I'd be scared of that. Or, is that the problem that I'm looking at ?
Mike
Old Jan 31, 2021 | 09:24 PM
Massimo Lucidi
Cheers,
Charlie
The same problem is what I had after I bought gkn axles. Thanks for the link!
Old Feb 10, 2021 | 09:26 AM
Thinker2112's Avatar
Thinker2112
Nearly 140K on the factory LSD and it's never popped out an axel. The factory LSD may not be what you all are really wanting but reliability is something.
67morris
May 17, 2020 09:17 AM
atice
Mar 19, 2012 10:07 PM
silvrcelt
Jan 20, 2010 07:38 AM
byhsu
Jun 3, 2008 08:10 AM
spam052
Nov 5, 2007 04:22 AM
