Drivetrain M7 Air Gain System... Sneak Peek
Old Dec 26, 2004 | 04:25 AM
  #26
jlm's Avatar
jlm
what goes upstream?
Old Dec 26, 2004 | 04:33 AM
  #27
JCampos's Avatar
JCampos
OOOH!! I KNOW I KNOW!!! SALMON!
Old Dec 26, 2004 | 04:53 AM
  #28
jlm's Avatar
jlm
you got me there!
Old Dec 26, 2004 | 08:08 AM
  #29
MSFITOY's Avatar
MSFITOY
Originally Posted by M7
Sid.........300
sorry...my math sucks Those who can't subtract, draw
Old Dec 26, 2004 | 09:43 AM
  #30
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Very,very soon.....
Two options will be available:
1. M7 Air Gain System $299.00
2. M7 AGS Pro w/62mm TB $599.00
3. Some other options wiill be available in the 1st quarter of 05.
peter
Team M7
562-712-3270
www.m7tuning.com
For those of us with an already upgraded 61 to 63 mm Throttlebody, can we still add the M7 AGS ($299)? Does it have to be your 62mm TB or will any of the aftermarket TB work?
I assume you have tested various sized TB- any real difference using your AGS and the 61 to 63mm TB?
Will you make a similar AGS for the MC?????
Old Dec 26, 2004 | 10:53 AM
  #31
M7's Avatar
M7
You can certainly use anyones TB may it be...stock,61,62,63mm the option
that we have coming, is if you have a standard TB and want to step up for
even better "Air Gain".
We have not addressed the MC at this time, but I have a design in mind to
up the air flow rate passively.
peter
Old Dec 26, 2004 | 04:23 PM
  #32
62Lincoln's Avatar
62Lincoln
Peter, will this system be compatible with factory intakes? The JCW system? Or...?
Old Dec 26, 2004 | 05:33 PM
  #33
M7's Avatar
M7
The M7 Air Gain System does away with all the stock/aftermarket tubing,
enclosures, heat shields, clamps, silicone tubing etc.
The whole idea with our system is to shorten the air path considerably
from filter to supercharger, and allow as much air flow/volume to enter
the SC as possible. With the M7 AGS, air delivery to the SC will not be
the bottleneck anymore.....
peter
Old Dec 26, 2004 | 05:44 PM
  #34
Mark@Helix's Avatar
Mark@Helix
Love to try this on our twincharged kit.
what is the unit constructed of? (cast or plastic?)
The install of this part is not so bad if you put the car in service mode and take the driver side intercooler outlet off together with the supercharger inlet.
Old Dec 26, 2004 | 06:06 PM
  #35
M7's Avatar
M7
It's rotary molded cross linked polymer...
Call me..
peter
Test piece in car.
Old Dec 26, 2004 | 06:42 PM
  #36
DarkMiniCooperS's Avatar
DarkMiniCooperS
Another great piece of art from M7 guys!!
Merry Christmas to u too and a happy motoring new year!!
Keep the good work
Old Dec 27, 2004 | 02:32 AM
  #37
uae mini's Avatar
uae mini
So this should fit your soon to come twin screw setup.. right?
Call me..
peter
Test piece in car.
Old Dec 27, 2004 | 10:31 AM
  #38
Fracky's Avatar
Fracky
Transwarp - Warp 10.0
Drool, drool, <puddle> drool
Very, very cool. After my brake conversion is done, we'll definitely need to talk. Keep up the great work!!!
Old Dec 27, 2004 | 11:21 AM
  #39
RUKnight's Avatar
RUKnight
I have to say I was skeptical at first just because the price was on the high side but now that I can see it it looks to be a damn nice system, great jog M7 guys! Can't wait to see some before and after dyno's on an otherwise stock car and then I'll come calling as well!
Mike
Old Dec 27, 2004 | 11:45 AM
  #40
miniraider's Avatar
miniraider
looks like is time for an instal party....
i am in guys. ...............
to M7 and the team happy holidays and great new year...
Old Dec 27, 2004 | 04:05 PM
  #41
Ryephile's Avatar
Ryephile
Where is the air filter?
Looks interesting - even if the mold is way rough looking.
I look forward to seeing the finished product.
Old Dec 27, 2004 | 04:39 PM
  #42
M7's Avatar
M7
The molded part is taken right from the mold without being cleaned of, so what
you see is mold release (not to pretty).
The filter is situated in forward part of the engine compartment, similar to an HAI set up. We will have more images as soon as our custom made filter is
finished (Blue cotton element S&B).
peter
Old Dec 28, 2004 | 06:27 AM
  #43
macncheese's Avatar
macncheese
Interesting idea, but I'm not sure I "get it." Whats the theory behind moving the TB and increasing the cross sectional area downstream of the TB?
Cheese
Old Dec 28, 2004 | 06:34 AM
  #44
Brain1.0's Avatar
Brain1.0
Manufacturer
Cheese
I have seen the setup and there is a very large differnece in the 2 intake tubes. Its hard to tell from the pictures but the stock tube is pinched in the center which would definatly minimize the flow and the M7 unit is not.
Thats about all I know and I am sure Peter can answer better.
Old Dec 28, 2004 | 08:17 AM
  #45
CTMINI's Avatar
CTMINI
Originally Posted by JCampos
Is there such a thing as spending too much on your MINI?
Not if you can afford it.
Old Dec 28, 2004 | 08:41 AM
  #46
sfjames2's Avatar
sfjames2
YES!!! Looks great Peter, can't wait to try it out. I bored out the stock intake runner awhile ago and believe it made a improvement in the higher RPM range. I posted about it, but no one seemed interested at the time.
Anyhow, looks like you've done it all with this intake system so send me one ASAP please.
James
Old Dec 28, 2004 | 09:25 AM
  #47
bigpmj's Avatar
bigpmj
For those of us with the ALTA or other aftermarket intakes...would it be worth it to step up to this? Cuz it looks bad ***.
Old Dec 28, 2004 | 10:56 AM
  #48
sfjames2's Avatar
sfjames2
, unless you think you'll gain more with 2 Alta CAI's.
Old Dec 28, 2004 | 11:15 AM
  #49
M7's Avatar
M7
Cheese
Hi Cheese.......
Free flowing, less restriction, larger cross sectional area, higher air velocity
bigger volume of air, straight air path etc etc.
The idea is to get as much air to the SC as possible, uninterupted by protrusions, bends and decresing cross sectional area (stock tube).
Our patented AGS tube has not only a superior flow characteristics
but we also molded in a velocity stack design, making the air velocity
higher then if a straight tube was implemented.
As we designed the AGS we looked at competing products (usual suspects)
and found that the airflow on most designs was solely dependent on
filter design and that was it........
Cheese I hope that answered you question, if not feel free to call us.
peter
Team M7
562-712-3270
www.m7tuning.cm
Old Dec 28, 2004 | 12:20 PM
  #50
BelowRadar's Avatar
BelowRadar
Wow...incredibly interesting little set-up. I can't wait to see how it looks installed and what the dyno chart reads. Will your baseline be a stock S or one that has other mods already installed? Will this increase in air flow (over say another aftermarket intake) compromise the SC more (in terms of exposure to dust and dirt)? Are you applying for CARB certification for this and/or the TB?
