Drivetrain MTH Dyno Results
Originally Posted by greatgro
1 - The evaporation of water on the intercooler can make a very big difference on the dyno and since no other MINI dyno techs do this, these numbers aren't comparable at all to anyone else's dyno.
Also mods that great more heat (pulleys, ECU programming to run leaner) are going to benefit greater from the extra cooling than a car in stock form.
If you put more heat into a system you need to get more out of it to show any gains you might have made. Ideally you want the exact same IAT and A/F ratios with and without a pulley to see exactly what difference the pulley made. Without extra cooling the mods will likely show less power than they should due to the extra heat they create. The question then becomes, How much cooling do i need? The limited amount of datalogging i have done indicates that the ECU actively retards ignition timing and increases fueling as the intake temps get hotter. In third gear, on the street, WOT, near redline I was seeing IAT's just over 140F, starting temp was 95F I think. It probably was a bit hotter but my datalogger has a VERY slow sampling rate.
On the dyno, in fourth with a squirrel cage blower Very close to the I/C I saw IAT's climb to 156F at redline from a starting point of 93F. with water spray only the IAT's made it to 142F starting at 97F ,and with both waterspray and the fan: 120F at redline started at 86F. Looks to me like the water spray is the way to go to ROUGHLY approximate street driving as far as IAT goes. Still need to get the water temps stabilized because they also have an affect on timing and fueling. This was all done with ambient air temps in the mid 60's.
So that will throw off your readings of how much power a mod made. Same car and same dyno yet b/c of the cooling factor, the mod may show more power than it really makes.
2- There is no SAE correction factor for forced induction so different dynos using different correction factors also make comparisons impossible.
Again i'm not trying to compare my dyno with anyone elses. However, Dynojets seem to read generally higher than the Mustang dynos from the very limited amount of information I have seen on Mustangs. NONE of the 5 correction factors our dyno has compensate for forced induction. I am not aware of any dynos that do compensate.
Even so, most dynos still show a stock MCS in the 140-145 whp range.
Don't forget the 05's are geared shorter in addition to a little more hp and are supposed to be several tenths quicker to 60. I don't think they're underestimating the power these cars make at all. Those figures sound right. :smile:
I'm not trying to be an as$, I promise.
Todd
Originally Posted by Mugami
The stock number being that high is why i stated impressive. On a local Dynojet so far we have tested 3 MCS with 15% pullies and the MTH programming. no cooling on the IC except a fan. All three pulled 178 hp at the wheels which is equal to about 200 at the crank. using the 12% drivetrain loss. Also did a JCW that was retro fitted with the 210 upgrade kit. it pulled 188 hp equaling to 210 hp at the crank.
The important part about these results done by ATSTODD isnt the numbers themselves in comparing car vs car. (different dyno's can give different reading of the same car) But the gain which is important since it was done on the same dyno in approx same conditions.
If i may ask Todd are you getting A/F readings when your doing the pulls. if so i would like to see them for the stock run and after you switch to the 15% pulley. We are going to be getting intouch with Franz on our finding to see if he can fine tune the setting for our area. So i would like to see the comparison
Thanks a bunch
Thanks a bunch
Todd
