Drivetrain Removing axles from transmission...
Old Apr 22, 2020 | 07:08 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
About a month ago, I made an attempt at a clutch replacement, and failed miserably. One of the items i struggled with was removing the drivers side axle from the transmission. For the life of me, I could not separate the clip from inside the transmission.
Does anyone have any tips or tricks for popping out the axle?
Old Apr 22, 2020 | 08:02 AM
thebombardier's Avatar
thebombardier
Rent/buy this tool:
Amazon Amazon
Traditionally it is supposed to be used with a slide hammer, however I found it extremely difficult to fit a slide hammer around all the other stuff in the wheel well. So what I did is snuck the tool between the CV joint and transmission and put the end of my jack handle up against it, then hit the other end of the jack handle with a 3 lbs mallot.
Old Apr 22, 2020 | 11:57 AM
oldbrokenwind's Avatar
oldbrokenwind
Really important that you pull it straight out --- not at an angle. The "C" clip inside needs to be able to compress as the axle is sliding out.
gforce1108
20
Jan 15, 2024 07:03 PM
nellis003
Mar 16, 2019 08:21 PM
ghurm001
Dec 22, 2017 09:25 AM
Bearybee
Dec 24, 2015 08:31 AM
one73ronin
Jun 22, 2014 11:15 AM
