Drivetrain Max Boost 17% overdrive
Old Mar 5, 2020 | 01:54 AM
cut7's Avatar
cut7
On an otherwise stock motor, how much boost can be expected with a 17% overdrive pulley? I'm looking for real numbers from people who have actually measured it, not guesses.
Old Mar 5, 2020 | 06:40 AM
BlwnAway's Avatar
BlwnAway
15-16 PSI on a stock system.
Keeping in mind that your results may vary since measured boost will be effected by ambient atmospheric pressure and ambient temperature.
Plus any modifications to the intake and charge system, not just the engine.
Old Mar 5, 2020 | 08:31 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
My map sensor peaks out at 215 kpa, logged it this past weekend at VIR, see link below. I run methanol (wiper fluid) to keep temps down.
VIR is 400' elevation so ~99.5 kpa, car makes 215 kpa so 113.675 kpa above atmosphere, that's ~16.5 PSI
I dont have the formulas in excel so I rounded a bit
https://podium.live/events/vir-grand...?laps[]=28
Old Mar 5, 2020 | 10:13 AM
cut7's Avatar
cut7
Thank you for the responses. I am now convinced that my MAP sensor is bad, because I'm seeing 34.5 psia at 5500 rpm, & since I am virtually at sea level (172 ft.) that would be ~20 psig.
Old Mar 5, 2020 | 10:17 AM
MrBlah's Avatar
MrBlah
Originally Posted by cut7
Thank you for the responses. I am now convinced that my MAP sensor is bad, because I'm seeing 34.5 psia at 5500 rpm, & since I am at sea level (172 ft.) that would be ~20 psig.
It sounds like there's some kind of correction being done by an app how are you logging that I'm using the raw OBD values
Old Mar 5, 2020 | 10:19 AM
cut7's Avatar
cut7
I'm reading the raw OBDII data; no app.
Old Mar 5, 2020 | 11:47 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
17 psi is the high point with a 17% pulley and stock head. If the car is got some wear, higher mileage, or ported head along with other mods it will be less. But again that is just the high point as many cars will be in the 15-16psi range.
Old Mar 5, 2020 | 12:29 PM
BlwnAway's Avatar
BlwnAway
Check the MAP sensor of course, but don't forget, unusually high boost can also be symptoms of a restriction in the exhaust as well.
Old Mar 5, 2020 | 01:24 PM
cut7's Avatar
cut7
One more piece to add to the equation. I just got a P0420 DTC code. I replaced one of the O2 sensors about a year ago.
Old Mar 5, 2020 | 05:11 PM
BlwnAway's Avatar
BlwnAway
Then yes, between the 0420 and unusually high boost, you may have a bad/plugged CAT.
Old Mar 5, 2020 | 07:35 PM
cut7's Avatar
cut7
https://podium.live/events/vir-grand-2020-mar-01/device/mini?laps=28
What hardware & app are you using to log your data?
Old Mar 6, 2020 | 04:18 AM
MrBlah's Avatar
MrBlah
racecapture pro mine is a mk2
It data logs canbus, obd2 and 5v sources, streams live to podium and my pi dashboard, you can see the dash here
Old Mar 6, 2020 | 09:13 AM
cut7's Avatar
cut7
Apparently, that app is free. What are you using to convert OBDII to Bluetooth?
Old Mar 6, 2020 | 09:33 AM
MrBlah's Avatar
MrBlah
the app only works with racecapture data loggers, I use a MK2
Old Mar 6, 2020 | 09:59 AM
cut7's Avatar
cut7
Oh...
Old Jun 15, 2020 | 10:21 AM
cut7's Avatar
cut7
Turns out it was a plugged catalytic converter.
dutch2081
Nov 28, 2012 05:20 AM
miniflip80
Aug 23, 2008 06:13 AM
33NIM
May 22, 2007 07:17 PM
willy69
Feb 9, 2006 07:19 AM
m444ssy
Oct 7, 2005 04:03 AM
