Drivetrain boost controllers
Old Feb 7, 2006 | 03:33 AM
willy69's Avatar
willy69
boost controllers
can a boost controller be used with a tc setup to limit boost to safe wot for a extended peroid of time? i think this would make a tc setup worth doing.
cheers
Old Feb 7, 2006 | 04:37 AM
betet's Avatar
betet
Sure it can, unfortunately unless you change to a bigger pulley, going TC will start you off at about 21-22 lbs of boost... So w/o a way of getting the supercharger produce a lower boost, you're pretty much at the "boundary". With the bigger pulley you will have a lower starting boost , (let's say 17-18 lbs), then just increase the boost w/ the boost controller..
If you can get Garret or whomever and convince them to create a WG Can of 4lbs is another way of having a lower boost. Final option is to just modify and put an external wastegate since I've seen these go low = 3lbs of boost.
///Gilbert
Old Feb 7, 2006 | 10:14 PM
minicoop78's Avatar
minicoop78
MMMMM wastegates...
Old Feb 7, 2006 | 10:18 PM
Tüls's Avatar
Tüls
Turbius Maximus
Originally Posted by minicoop78
MMMMM wastegates...
dood waste gates don't work...I mean gosh...whatever....how is that possible
Old Feb 7, 2006 | 10:28 PM
Maximusmini's Avatar
Maximusmini
Haa Haa.. You can actually buy a lighter spring/diaphragm for your internal wastegate, and use your boost controller to limit a smaller amount of psi..
Old Feb 8, 2006 | 11:12 AM
Minirowski's Avatar
Minirowski
MMMMM wastegates...
Is that picture from a mini?
Old Feb 9, 2006 | 12:47 AM
minicoop78's Avatar
minicoop78
yes it is mine. much more to come
Old Feb 9, 2006 | 07:19 AM
Maximusmini
Let me guess, a Tial 38mm external? :p or as my roommate says,"Turbo SS chinese knockoff"
Filmy
15
Jun 6, 2023 06:27 AM
molala
Oct 2, 2015 01:53 PM
Sep 11, 2015 11:09 AM
mbatech
Sep 10, 2015 03:40 PM
Filmy
Sep 7, 2015 11:27 AM
