Drivetrain ANYONE TRIED THIS? Cel fix 02 sensor
Old Dec 17, 2018 | 07:49 PM
Serafin's Avatar
Serafin
hello in apologive if this has been covered. But can’t seem to find a current one.
Anyone tried this? Looks promising. Or other spaces that’s proven to work?
http://www.bigdaddiesgarage.com/mini-cat-cel-fix.html
I’m about to instal a careless headers with my 2006 r53 and heard the i need some sort of spacer to eliminate the heck engine fault code.
Thank You
Old Dec 19, 2018 | 04:29 AM
David Baker's Avatar
David Baker
While it isn't advisable to run a street car with no catalytic converter, you would need the spacer with a 90 degree bend in it. The rear O2 sensor is a snug fit anyway and there is little to no room to add a simple spacer. You would be better served with something like this:
90 Degree O2 spacer - Amazon 90 Degree O2 spacer - Amazon
Old Dec 19, 2018 | 06:20 AM
Serafin's Avatar
Serafin
awesome. Have you used this? Besides the fitment. Will it work as advertised for the mini?
thanks
Old Dec 19, 2018 | 06:37 AM
ThumpR52's Avatar
ThumpR52
I have tried 90% spacers as well as a harness with a capacitor and resistor being in place. I have a friend that says a 45% offset will work. I also have an Ultragauge that I monitor the O2 voltages with. I am thinking there is both a range that the ECU looks for and also a time interval of the range under WOT. The harness I spoke of works very well with warmer weather and after the engine temps are at operating range. It is under WOT when cold that a CEL will come on regardless of the spacer that is why I am thinking there is a time interval involved as well.
I have an OEM section that I install come vehicle inspection time
Old Dec 19, 2018 | 06:56 AM
Serafin's Avatar
Serafin
i see. So this 90 degree spacer should work. By itself or i need to add the other spacers also?
Old Dec 19, 2018 | 07:11 AM
ThumpR52's Avatar
ThumpR52
I have had codes thrown with the 90.
Old Dec 19, 2018 | 07:14 AM
Serafin's Avatar
Serafin
mmmm 🤔 that mini car looks promising. But they replied to me and said it wouldn’t work. Maybe get that and the 90 together.
Old Dec 19, 2018 | 02:55 PM
MrGrumpy's Avatar
MrGrumpy
I have a CNT Racing 90 degree spacer. Brand new, never installed. If you want it, PM me and we can work something out. I have no use for it since the O2 DTC is coded out with my tune
Old Dec 21, 2018 | 09:09 AM
Oldboy Speedwell's Avatar
Oldboy Speedwell
So,
is there an answer to this?
Would something like this work?
https://www.ebay.com/itm/45-Degree-C...-/263680812262
Or something like this?
https://www.bimmerworld.com/Oxygen-S...r-E36-MZ3.html
I've read some stuff about a slight loss of torque after de-catting,
is that true?
I've heard some people say that the exhaust sound may become raspy and hollow sounding, but I'd guess it depends on what the system is.
This one sounds damn good imho:
Old Dec 21, 2018 | 10:45 AM
ThumpR52's Avatar
ThumpR52
A 200 high flow cat also has a nice sound.
Old Dec 21, 2018 | 11:03 AM
I like mini clubman's's Avatar
this high flow cat appears to be want I'm looking for. I'm putting in a careless down pipe and I'm relocating the cat under the car. I'm doing this for several reasons, one being to install the high flow cat.
What is a 200 high flow cat?
Old Dec 21, 2018 | 11:05 AM
Quick Google search found it, 200 "cell" high flow cat 👍
Old Dec 21, 2018 | 11:16 AM
Oldboy Speedwell
Yeah, I looked up the high flow cat too --- a little surprised they can be had for so inexpensive.
But will they work?
Or will they throw a CEL?
Even some of the big name headers with a sports cat have had problems with their aftermarket cats triggering CEL.
Old Dec 21, 2018 | 11:52 AM
Oldboy Speedwell
Does anyone stateside do up something similar with a stock cat like 1320 did with their Tom-Cat?
https://www.1320.co.uk/the-tom-cat-f...peed-manifolds
It has been proven effective with many good reports.
Alternatively,
back to the spacer/simulator thingies...
...a trusted NAM member said one of these:
https://www.summitracing.com/parts/v...BoCvlUQAvD_BwE
...worked well in his application:
https://www.northamericanmotoring.co...ml#post3971756
Old Dec 21, 2018 | 01:23 PM
Serafin's Avatar
Serafin
Originally Posted by Oldboy Speedwell
So,
is that true?
https://www.youtube.com/watch?v=o0N6u3OU2NQ
just ordered the 90 degree one from amazon. But yours looks promising. But i don’t think that’ll fit. There’s really no room there
Old Jan 8, 2019 | 12:36 PM
Serafin's Avatar
Serafin
It works!
so here an update. Finally installed my headers. And used the 90 degree adaptor and no check engine light. I’ll keep y’all posted after 100 or so miles after the weekend.
What did you you guys end up doing redarding the top hearsheild ? Cut the sides and the mount it? Or is there an aftermarket hearsheild for headers?
Old Jan 22, 2019 | 11:20 AM
JupiterR53's Avatar
JupiterR53
Interested in sound clips as well as I live in Florida with no emissions laws...
As for heat shields, honestly, you can get away without them on a catless car because the heat is much lower. A catalytic converter works on the principle that it gets insanely hot to burn any residual combustible gases in the exhaust. THAT is majority of what the heatshields are for. By removing the cats, you reduce temp greatly in that area. Now, that being said, if there are brake/fuel lines in close proximity, you'd still want heat shields for that reason.
In terms of experience, I had a BMW X5M and I installed catless downpipes (twin turbo V8, turbos in the Vee and cats RIGHT behind them against the firewall). The underhood temps dropped dramatically just by doing this, it was unbelievable.
I don't have experience with the O2 spacers, but I'd be curious to their effectiveness, this would make me much more interested in getting a header or punching out the stock cat...
Old Jan 22, 2019 | 11:41 AM
Serafin's Avatar
Serafin
currently out of town, its actually not that loud at all having a 1 ball mod.. no droning on the interstate. I'll get one as soon as I get back Home this sun.
As far as the heat shield goes, I took the rivets out and did a little bending and put it back on
greystone
Apr 1, 2014 05:58 AM
kconner5
R60/61 Cooper S Drivetrain
Jun 7, 2013 09:18 AM
eurodriver
Aug 23, 2012 04:00 PM
