Drivetrain Hard pipes from Forge, What can they do?
Old Mar 25, 2019 | 12:46 PM
  #26
hadjiikong's Avatar
hadjiikong
I did purchase it directly off of the Forge website under the JCW model. They must have shipped me the incorrect one. Will have to contact them.
Old Mar 25, 2019 | 12:47 PM
  #27
SoCalF56's Avatar
SoCalF56
Sorry to hear that :/ Let us know what happens!
Old Mar 25, 2019 | 12:48 PM
  #28
Yep, just reach out to them and they should be able to get you the correct one.
Old Mar 25, 2019 | 12:55 PM
  #29
Mini_Vinnie's Avatar
Mini_Vinnie
Moderator
Just wait, we can try to install mine and we can trade parts because i ordered the JCW too
Old Mar 25, 2019 | 01:01 PM
  #30
SoCalF56's Avatar
SoCalF56
Are any of you planning on doing a ceramic coating or heat reflective tape on the outside of the pipes? I would assume once the metal heats up it will be a big source of heat soak. I was considering installing these as well, as im convinced the stock plastic charge pipes/intake runner are one of the main sources of heat soak on this car. Even with intake and intercooler, im running double ambient intake temps once my car gets up to temp.
Old Mar 25, 2019 | 06:58 PM
  #31
Mini_Vinnie
Moderator
I thought about wrapping or using that tape for sure
Old Mar 26, 2019 | 01:39 AM
  #32
Clutch Wotan's Avatar
Clutch Wotan
Funny wise the guy which do the video about E-Venturi ( MINI Team Dombeck), states 7HP gain on the Dyno for the Forge main tube, which however gets hot as hell. I think that the heat from the turbo crawls through, a protection might be useless ? On the other hand the air volume which goes through is massive, so that contact with inner tube might be minor.
Old Mar 26, 2019 | 01:46 AM
  #33
Clutch Wotan
Originally Posted by Mini_Vinnie
ahh, interesting
Can be a good seller for E.Venturi clients CST ( Colored shaped tape $12/ea.) to close the scope , the open scope of the R56 did pull air out.
Old Mar 26, 2019 | 07:33 AM
  #34
hadjiikong's Avatar
hadjiikong
I am sure coating and wrapping it would help but at least on my JCW I do not think I could do the whole pipe where it connects to the inter cooler. It was so tight I had to jack up the inter cooler to have enough space for the clip to unlatch.
RudeJoe
Jul 8, 2020 10:23 AM
Erhan
Oct 26, 2011 07:58 PM
kadaj
May 18, 2011 04:05 AM
mitemini
May 1, 2009 06:10 AM
STLMINI
Driver's School
May 23, 2008 07:11 AM
