Drivetrain Noismaker delete with meth injection
Old May 2, 2018 | 09:17 AM
destr0's Avatar
destr0
I have been working on my Mini quite a bit lately - In the last 45 days:
New wheels and tires - lightweight 17x8 wheels and 235-40/17 UHP tires
Alta Sway Bar
FMIC
Still to go in:
3" cat delete downpipe
2.5" straight pipe exhaust
turbo that doesn't spew oil - stock bad turbo will get sent out to be rebuilt as K03/K04 hybrid. This was the plan, but my turbo has recently decided to spew lots and lots of oil.
DIY water/meth kit - this has been in process for a while, mostly because finding the right fittings are a PITA.
In looking at where to mount the injection nozzle, I came up with an idea - mount the nozzle into a plug that deletes the noisemaker. I think it should work out perfect - the pump and solenoid will be on the firewall just to the drivers side of my AEM intake - nice and short shot to the nozzle. Using factory washer bottle for fluid.
Old May 8, 2018 | 12:21 PM
BigBoost's Avatar
BigBoost
You need to place the meth nozzles before the map’ other wizes your ecm will not read the temp difference an not work right !
Attached Thumbnails Noismaker delete with meth injection-bf91107c-c630-49a4-bb30-46a80fefc6f5.png
Old May 8, 2018 | 02:37 PM
destr0's Avatar
destr0
On the N14 isn’t the MAP sensor in the intake manifold? Noisemaker is upstream of that so putting meth nozzle in noisemaker delete plug should work, right?
I have never ever touched my MAP sensor but thought it was in the intake itself.
Old May 8, 2018 | 08:16 PM
BigBoost's Avatar
BigBoost
They are all technically MAP sensors !
One is a manifold sensor
The other is a boost sensor
You need the nozzle before the boost sensor ‘ just like the photo I posted’ check out aquamist install kit guide ‘
Old May 18, 2018 | 07:50 PM
oldbrokenwind's Avatar
oldbrokenwind
The sensor on the manifold measures manifold vacuum/pressure. The sensor on the intake pipe, near the fender liner, measures both boost and temperature, that's why the WMI should be before the 1st sensor --- to sense the WMI cooling and make appropriate ECU adjustments.
IQRaceworks
Nov 29, 2018 07:36 AM
Mini Coupe
May 17, 2011 08:00 PM
smackboy1
Nov 21, 2010 06:56 AM
Mini_MEL
Nov 1, 2006 04:23 PM
