Drivetrain RMW Big Valve R56 cylinder head
Old Mar 13, 2018 | 07:20 AM
Revolution Motor Works's Avatar
Vendor
New guides, seals and CNC porting
I worked with Supertech to develop the valvetrain with beehive springs and titanium retainers
Custom oversized valves for intake/exhaust with inconel material which can withstand 2000 deg F
each head is surfaced flat and ready to install
Our heads are on many cars around the world
Only head out there with actual head flow numbers. Ask anyone selling you a head for theirs. Know what you are buying
Pricing is $2550 plus a good head core
Oversized intake and exhaust valves with Beehive springs good to 35psi and 9200rpms! Single groove keepers, titanium retainers are standard. New valve guides, custom valve job and superior performance in a cylinder head
Old Apr 4, 2018 | 07:26 AM
Kirk M's Avatar
Kirk M
How much HP does this typically add?
Old Apr 4, 2018 | 07:47 AM
Vendor
depends on how much boost you put to it
the more you put to it, the more it will make over the stock one
Old Apr 4, 2018 | 08:37 AM
cerenkov's Avatar
cerenkov
For the N18?
Old Apr 4, 2018 | 08:59 AM
Vendor
Originally Posted by cerenkov
For the N18?
yes, it can be done for both heads
Old Apr 5, 2018 | 04:03 AM
BMC_Kid's Avatar
BMC_Kid
Let's say you put the same boost into it as the stock. How much additional hp should you expect to see?
Old Apr 5, 2018 | 08:34 AM
Vendor
20+ depending upon what your tuner does
Old Apr 5, 2018 | 09:31 AM
mbwicz's Avatar
mbwicz
Do you have cams that are matched to your head?
Beautiful looking work, really well done.
Have fun,
Mike
Old Apr 5, 2018 | 10:35 AM
Vendor
Have fun,
Mike
any good cam grinder can use the flow data above to make some fantastic cams for the head.
Old Apr 25, 2018 | 01:57 PM
hidperf's Avatar
hidperf
Do you have any recommendations for cam manufacturers who can actually do custom cams for the N14? I've only found companies that have their own grinds.
Old Apr 25, 2018 | 05:34 PM
Vendor
at this time I don't have a cam manufacturer to give a rec to. Newman who grinds all of our cams for the 1st gen cars was working on getting blanks for these but at the current time I believe they don't have anything. I'll check tomorrow.
Old Apr 26, 2018 | 10:38 AM
cornjuice's Avatar
cornjuice
Love IT!! Show me more!!
Q - any chance of port matching big plenum R53 intake mani to this head? I want to ditch the OEM plastic manifold and the R53 mani looks like the (almost) perfect way to add port injection at the same time. There are few/no options available for this route on R56 without fab it looks like though.. which is why i ask.
Old Apr 27, 2018 | 07:12 AM
R56BrgMcs's Avatar
R56BrgMcs
That's almost too good looking to put in a car!
Old Apr 27, 2018 | 08:22 AM
Vendor
anything is possible, it's only money
I'm shocked more people haven't built something for the 2nd gen already. Me, personally I won't do anything for the car until there is a proper solution for the tuning. I constantly get people coming to me asking for a stand alone because their cars don't run right with the bigger turbo setups of what's offered out there. By the number of them that come for engine rebuilds I would have to agree
Old May 17, 2018 | 04:25 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
Does this mean the days of piston #3 failures are coming to an end? I see rmw has pistons/rods now. I've held off on building a R56 due to the tuning/failure issues. SCCA classes them so much better for autocross & TT, and the platform is faster on the track.
I keep resisting switching but maybe there's less reason not to?
Old May 17, 2018 | 08:11 AM
Vendor
there is some really bad tuning going on out there. The amount of blown engines in the 2nd gen is extreme
obviously good rods/pistons will make a difference. I'm the only one out there to address the oil consumption issue by designing a proper ring package for the pistons. I have custom rings made by Mahle Motorsports division.
kennyshi
May 21, 2018 03:06 PM
solskjaer1999
May 12, 2014 07:47 PM
jhiggs26
Aug 26, 2013 04:56 PM
smv
Jul 31, 2008 03:20 PM
