Drivetrain 1st to 2nd wheel spin
When under heavy acceleration going from 1st to 2nd, sometime (not all the time) I experience wheel spin. I have only experienced this a few times.
Stupid Question:
Does this hurt the clutch and tranny?
And what would be the tell-tail signs?
I have 3k on my MCS and want to make sure it stays intact.
It's just so fun to drive and that is like an added bonus...
I know it's silly but hey...
Stupid Question:
i have 80,000 miles on my clutch and im on my 5th set of tires in 2 years so im like hella heavy wheel spinner, youed think im trying to break my car but shes still holding up great and rock tight, showing no signes of ware and still engages great!!!!
I never get wheel spin. Doesn't matter what gear.
Wheel spin might look impressive but it just means you have no traction for the moment on your drive wheels. No traction translates to no motion.
You can practice getting smooth launches from a stop by easing on the throttle just enough but not to the point of wheel spin and letting out the clutch at the right speed to avoid bogging down. Just takes practice.
Having a limited slip differential might help allow better front wheel traction. Turn off DSC if you have it when you practice your launches.
Your wheel spin hurts your tires alot but not your clutch or tranny if you do it smoothly.
Originally Posted by gravedgr
I get wheel spin when shifting to 3rd sometimes.
I can get wheel spin in my Maxima with street tires but they are hardly the performance wheels I have on my MCS. The Maxima has plenty of torque and power so no big deal with a bit more noise from the wheels.
Originally Posted by Azwed
I have got rubber in third once or twice but only on subpar road surfaces.
Stupid Question:
Stupid Question:
chris
Wheel spin isn't the end of the world. Sometimes it's the best way to go! I notice that some cars sort of bog down at shifts because the tires grip and the RPMs go down. If you can break the tires loose a little on your shift you can keep your RPMs up, and the wheels will connect pretty quickly anyway.
Stupid Question:
*Tell tale signs are a dramatically increased tire budget
Smoke 'em Cowboy
Originally Posted by Ryephile
*Burnouts don't hurt the tranny/clutch as much as NOT doing burnouts with same power being output from engine. Better to burn rubber than burn clutch.
Smoke 'em Cowboy
Smoke 'em Cowboy
chris
R50/53 2002 R53 Creaking/Clacking
maestro39
Oct 27, 2015 02:38 PM
tacticalbacon02
Aug 22, 2015 06:05 PM
