Drivetrain AWE MINI F5X S-FLO Carbon Intake. Available now!
Old Mar 30, 2018 | 01:56 PM
  #26
#Dragon#'s Avatar
#Dragon#
I have this intake and have to say it was well worth the wait .
I tried to order it direct and was told I had to use awe europe as I live in the UK but that one did not work out after a two month wait as my intake did not go in there container so I imported one my self from out motoring and had it in a week happy days.
Old Mar 31, 2018 | 04:18 AM
  #27
trentiles's Avatar
trentiles
Did the price go up? I don't remember it breaking the $400 mark
Old Jun 25, 2018 | 07:49 AM
  #28
Josh/AWE's Avatar
Josh/AWE
We have confirmed the AWE S-FLO Carbon Intake to fit the 2019 MSC (2-door and convertible models) as well as JCW models!
Old Jul 18, 2018 | 01:52 PM
  #29
shmandrew's Avatar
shmandrew
Josh - I picked up the intake used from a friend and am experiencing a P00BD code for "Mass Air Flow (MAF) A Circuit Range/Perf Flow Too High." Friend did not have any codes in the approx 8000 miles he used it. Everything looks to be in perfect shape and installed easily following AWE's instructions. Any idea what the issue could be?
Old Jul 18, 2018 | 02:14 PM
  #30
Josh/AWE's Avatar
Josh/AWE
Fill out this form as soon as ya can.
Old Jul 18, 2018 | 02:57 PM
  #31
shmandrew's Avatar
shmandrew
Thanks. Will do once I get home.
Old Jul 18, 2018 | 03:29 PM
  #32
camptown's Avatar
camptown
I would recommend you clean and oil the air filter. Doing so helps the air flow and I clean my filter every 10,000 miles or so.
Old Jul 18, 2018 | 06:40 PM
  #33
shmandrew's Avatar
shmandrew
Thanks. The filter looks very clean but I guess it wouldn't hurt to clean and oil it. I have a K&N cleaning/oil kit - can I use that or do I need something special from AWE?
Although the last thing I want is more airflow at this point - CEL says I already have too much
Old Jul 29, 2018 | 11:24 AM
  #34
Lionel Hutz's Avatar
Lionel Hutz
AWE: have you applied for a CARB EO for this intake? For what models/years?
Old Jul 30, 2018 | 06:03 AM
  #35
Josh/AWE's Avatar
Josh/AWE
Not yet, but CARB approval is coming.
Old Aug 2, 2018 | 08:38 PM
  #36
Propak's Avatar
Propak
How is the fitment on a 2019 F60? The Cravenspeed CAI (for F56) fits the F60 minus one mounting bolt. Have you tried it in a F60?
Old Aug 3, 2018 | 04:53 AM
  #37
Josh/AWE's Avatar
Josh/AWE
Negative.
Shoot me your VIN via PM and I'll cross reference.
Old Aug 5, 2018 | 10:46 AM
  #38
shmandrew's Avatar
shmandrew
Just an update on the CEL issue I was having... I brought the car into the dealer and had it smoke tested. Turns out the charge pipe was faulty and causing a vacuum leak. It was replaced under warranty and after about 300+ miles of driving I can report the CEL has not come back. Normally it would come on within 10 miles of clearing it. Kind of strange that the CEL was only triggered with the aftermarket intake installed and ran totally fine on the stock airbox. I guess the leak coupled with the increased airflow was enough to trigger it while the leak with the stock box must have still been within spec for some reason.
Old Aug 6, 2018 | 06:28 AM
  #39
Josh/AWE's Avatar
Josh/AWE
Glad you were able to get it sorted
Old Aug 14, 2018 | 08:39 PM
  #40
Propak's Avatar
Propak
Installed the Awe S-flo on my 2019 F60 and it fit perfectly. I did a video of the 30 minute install and will post soon.
Old Aug 15, 2018 | 08:40 PM
  #41
Propak's Avatar
Propak
Install vdeo 2019 F60
Heres a video of the install I did last night. Simple install. Good instructions. Perfect fit. Great sound! Video is uploading ATM and will be ready by 1am 8/16
Old Oct 9, 2018 | 01:39 PM
  #42
Josh/AWE's Avatar
Josh/AWE
Old Oct 11, 2018 | 02:52 PM
  #43
#Dragon#'s Avatar
#Dragon#
Hi josh
if I was to change one thing on your design of this CAI it would be to add a rubber grommit to the retaining arm were the bolt goes through just like the stock air box as what I find is that the retaining bolt works loose because the CAI cannot move with the engine.
Old Oct 11, 2018 | 04:02 PM
  #44
NBCGLX's Avatar
NBCGLX
Does this fit the F5X 3-cylinder, too?
Old Oct 12, 2018 | 02:21 PM
  #45
shmandrew's Avatar
shmandrew
Originally Posted by #Dragon#
Hi josh
Agreed. My bolt worked itself free and has vanished
Old Oct 15, 2018 | 06:48 AM
  #46
Josh/AWE's Avatar
Josh/AWE
Folks, blue Locktite would be recommended for such.
Old Oct 15, 2018 | 07:06 AM
  #47
NBCGLX's Avatar
NBCGLX
Does this intake fit the F5X with the 3-cylinder?
Old Oct 15, 2018 | 07:44 AM
  #48
Josh/AWE's Avatar
Josh/AWE
Part numbers for that motor are different. May fit, but cannot confirm.
Old Oct 15, 2018 | 01:53 PM
  #49
#Dragon#'s Avatar
#Dragon#
or ptfe tape on the thread of the bolt
Old Nov 13, 2018 | 06:34 AM
  #50
BlackMarket's Avatar
BlackMarket
Smile I Love it!
I love this thing! It looks great and sounds great, and it feels tons more responsive. I also have the Forge High Flow Intake Hard Pipe.
Forge Hi Flow Intake Hard Pipe & AWE Carbon Intake
