Drivetrain reverse water flow
Old Sep 9, 2017 | 07:20 AM
Yyrd's Avatar
Yyrd
reverse water flow
I been thinking about reversing the flow of the water so the water cools the head first. as GM did with the LS1. idea is it will provide a cooler head, hence lower detonate chance.
I already have a electric water pump. and will need to run it to the head, and switch the thermostat to the lower block. and lost of fun piping.
what does anybody think on this?
Old Sep 9, 2017 | 07:27 AM
Whine not Walnuts's Avatar
Whine not Walnuts
Could you get a reverse polarity pump and just make a housing for the t-stat that sits outside the original mounting point? Would need to make sure there are no back check valves anywhere in the system.
Old Sep 9, 2017 | 09:27 AM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
cooler heads don't always prevail
I don't mean this to be an attack. But I would wonder if I would think I know better than the BMW/Mini/Chrysler/Rover engineers. Cooler heads don't always prevail. Just think of what if the features in the coolant path may not be designed for reverse flow. The radiator is one such instance.
Old Sep 9, 2017 | 09:56 AM
pnwR53S's Avatar
pnwR53S
I probably should have cite the thermostat as a first consideration as the dire consequence of reversing the flow direction, if nothing is done about it orientation.
Old Sep 9, 2017 | 11:09 AM
Yyrd's Avatar
Yyrd
if we follow bmw engineers as the last say so, we all have 167 horsepower.
Old Sep 9, 2017 | 11:11 AM
Yyrd's Avatar
Yyrd
i would print a new Thermostats housing to mate to the current waterpump location. and move the waterpump to the current positioning on the head. then flip the radiator hoses
Old Sep 9, 2017 | 01:58 PM
pnwR53S's Avatar
pnwR53S
So your notion for the justification for reversing the flow is you think it tend to negate knocks. The problems for the engineers are, they have to worry about the recurring cost, driveability for everywhere the crap Mini is sold, emission, reliability, economy, over your citing of you think lower head temperature will tend to negate tendency for knock.
If you think it is so easy to swap the intake and outlet of the radiator do show us how you manage to do that.
Is lower head temperature better? It would depends on your perspective and lucky you, you don't need to worry about corporate CAFE, thermodynamic efficiency, warranty claims, and regulatory requirements? Is your motivation solely based on your notion that lower head temperature, the less tendency for knock? Are you experiencing head temperature limitations because you are pushing the envelope of HP/liter that no one has gone before?
Are you ready to instrument to measure the temperature of various points of the engine to ensure you are not compromise reliability over your believe that lower the head temp the better? I would worry that by reversing the flow direction, the side effects of unintended hot spots.
Old Sep 9, 2017 | 02:17 PM
Whine not Walnuts
Some good responses here, going to move to the Mod Section.
Old Sep 10, 2017 | 02:35 PM
Eric_Rowland's Avatar
Eric_Rowland
It's a "thing" in the Miata community. At least for high boost applications.
That is all.
Old Sep 10, 2017 | 05:02 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
Yyrd, what mods do you have or have planned that would warrant and justify such an undertaking? "Inquiring minds want to know".
Old Sep 12, 2017 | 01:06 PM
CSP's Avatar
CSP
Interested for science.
PNW has some good points.
