Drivetrain Cusco LSD
Old Jun 3, 2017 | 07:04 PM
MiniMoic's Avatar
MiniMoic
Cusco LSD
Its been forever since I installed a Cusco LSD in my GP. What do I need to check to verify its been working as it should. I dont even remember how different it was..!!!
And what about maintenance?
Old Jun 3, 2017 | 09:52 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
Simplest thing I can thing of is to put one front wheel on ice and the other on pavement, then try to accelerate. Since you're at 8200 feet just wait a few months?
There are a couple of on ramps here where if I hit it hard, I can get a little wheelspin on the inside tire, especially if it is wet. So you could try that. Find one that's a left hand turn, one that's a righty.
Old Jun 4, 2017 | 03:45 PM
MiniMoic's Avatar
MiniMoic
I can put the car on jacks and try to spin the weels. That works with clutch type LSD, doesnt it?
Old Jun 17, 2017 | 01:06 PM
MiniMoic's Avatar
MiniMoic
Ok so the car is on jacks and spinning the wheel in one direction makes the other spin in the same direction. I just wonder how to test my Cusco LSD to make sure it works
Old Jul 4, 2017 | 08:00 AM
brightside's Avatar
brightside
Try out this test to see how much your LSD is allowing slip.
Old Jul 4, 2017 | 08:37 AM
MiniMoic's Avatar
MiniMoic
Originally Posted by brightside
https://www.youtube.com/watch?v=a3sToq9ah60
Thanks! Interesting, but is that the test where the wheels are on the air? I did that and in neutral both wheels just turn.
Old Jul 4, 2017 | 11:28 AM
brightside's Avatar
brightside
Put it in gear and lift one wheel is how you would do that test.
Old Jul 4, 2017 | 04:45 PM
MiniMoic's Avatar
MiniMoic
thanks! I will try this test
Old Jul 5, 2017 | 06:00 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
that does not work with helical diffs or with diffs like the OEM setup they behave like an open diff when there is no load on both
the oem is driven by pressure load out from the center, causes the outside notched ring to engage it's a nifty setup but not a terribly high transfer %
Old Jul 5, 2017 | 06:47 AM
MiniMoic's Avatar
MiniMoic
I have a Cusco LSD which is a clutch type LSD
