Drivetrain Performance Upgrades Evolution
Old Sep 15, 2016 | 11:02 PM
Stripeknight's Avatar
Stripeknight
I have a 2005 R53 with less than 30k miles on it, I have added the 16% pulley as well as the air intake and the ATI damper, what are the next few mods most would suggest for peformance out of the drive train?
Old Sep 16, 2016 | 07:30 AM
Saltysalt's Avatar
Saltysalt
how much money are you willing to spend? the pulley is the most cost effective, intake does very minimal. makes a really good sound. a header also frees up the flowing exhaust, helps a lot midrange and up top, I felt a tad loss in low end but I am also catless and basically minimal exhaust backpressure.
you can throw in a cam, and possibly a adjustable cam gear and get a bit more, that cost about $700 together, or around $400 for the cam, that will give some more ponies, then can finish that all with a tune, and you should be around 220whp. you will have a harder time with traction at that point.
then theres a big valve head, which will port both sides allowing more air into the engine, valves are also enlarged, with this and tune youll be around 250-260 whp, definently struggling with traction without a LSD.
and that limits power adders for mechanical, at this point with your pulley, the s/c is also maxed out
Old Sep 16, 2016 | 07:35 AM
Racingguy04's Avatar
Racingguy04
depending on what your goals are, I'd probably do a header/exhaust next, then injectors, cam/head, and once you're happy with your mods, get a tune to make them all work together well.
I'd also consider the alta intercooler diverter, an oil catch can, and maybe ignition/wires.
Old Sep 16, 2016 | 12:11 PM
sevin's Avatar
sevin
Good information here. If you want to go higher than ~250whp, you'll need to start pestering Jan for his new 1.8L stroker and S/C kit. Our very own BlimeyCabrio has an R5x making 350+whp. Check out his build list (and blog), here.
Old Sep 17, 2016 | 03:12 PM
Mini Mania's Avatar
Upgrades
Hi Stripeknight:
We have a handy performance upgrade guide assembled by our experts with years of experience on all models. There's some good info here on engine, exhaust, suspension, etc. Cat Back and ECU upgrade would likely be next. We can help with both. Please feel free to ask any an all questions!
http://new.minimania.com/Mini_Cooper..._for_your_Mini
Old Sep 18, 2016 | 08:14 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
If you don't have a catback that is what I would lean toward. Saving weight, gaining torque and a nice sound our Strat system would be ideal.
https://www.waymotorworks.com/stratm...3-hardtop.html
Or one of our mild cams will be a nice addition without extra parts needed.
https://www.waymotorworks.com/way-mi...t-r52-r53.html
Otherwise put together a goal and a budget and we will work with you to get to it.
froggy_07
Sep 7, 2016 08:07 PM
Whale
Sep 7, 2016 01:23 PM
cflowrider
Aug 31, 2016 01:57 PM
Scooter24
Aug 27, 2016 01:40 PM
NikiMae31
Aug 26, 2016 05:18 PM
