Drivetrain New clutch/flywheel
Old Sep 21, 2016 | 12:31 PM
  #26
grussell's Avatar
grussell
Our Mini is still at the dealer. I will not be letting the dealer do the work because they said no warranty on clutch, so they will not tear it down. I was driving it when the clutch went out. I shifted into 3rd gear, there was a sound like something broke and then no I coasted to a stop. No forward or reverse movement after that.
Old Sep 22, 2016 | 05:52 PM
  #27
gjxj's Avatar
gjxj
that sounds very clearly like something broke. when you say no forward or reverse you mean with the engine running you can just shift gears with no resistance and no clutch?
Old Sep 22, 2016 | 07:34 PM
  #28
grussell's Avatar
grussell
Correct, there is no clutch engagement.
Old Sep 24, 2016 | 10:28 AM
  #29
gjxj's Avatar
gjxj
its very strange, most things that would fail like the shift fork would leave the clutch permanently engaged. Even a seriously worn out clutch disk would have a little drag to it.
Are you sure it isn't a linkage failure?
Old Sep 24, 2016 | 06:08 PM
  #30
grussell's Avatar
grussell
I never had a chance to look it over as it went from the side of the road to the dealer. The dealer said it needs a new clutch, but did not take it apart. The dealer we bought it from in July has agreed to buy the parts and as of now I plan to do the work. But I will do a complete inspection.
Old Sep 27, 2016 | 08:57 PM
  #31
Mini Mania's Avatar
Here is some good background information on your year and model clutch and flywheel, along with an explanation of the dual mass and an application guide.
Please take a look and let us know if you have any questions!
Plus, welcome to NAM and please post some pix.
http://new.minimania.com/Search_Resu...clutch/default
Old Sep 27, 2016 | 09:40 PM
  #32
grussell's Avatar
grussell
Good info, thanks. The dealer we bought it from has agreed to buy the parts and looks like I will do the install.
Old Sep 29, 2016 | 07:44 PM
  #33
DickieRich423's Avatar
DickieRich423
Thank you everyone for the input and discussion. It has helped immensely in the research.
Still no final desicions on one yet, but everything is helping.
Old Oct 5, 2016 | 07:03 PM
  #34
grussell's Avatar
grussell
I got our MINI home yesterday. The dealer had it for 9 weeks for the thermostat replacement. They paid for the rental car though. I thought I would replace the clutch myself. I had watched the video of the guy that did a write up and thought I could do it, but the All4 is a different animal. The rear drive shaft and complete exhaust from the down tube has to be removed and the front end and subframe have to come off which is a big job. So I am having an independent shop do it for me. Ended up getting a Valeo clutch kit and a Sachs DM flywheel.
Old Oct 6, 2016 | 12:13 PM
  #35
Mini Mania's Avatar
clutch flywheel
Please keep us posted as to how it all works out!
Old Oct 6, 2016 | 10:30 PM
  #36
grussell's Avatar
grussell
Decided to do the job myself this afternoon. I am 5 hours into it and didn't have big enough wrenches to remove the front driveshaft nut at the transfer case and no place open to buy them. Once the driveshaft is off I am probably an hour from having the transmission on the ground. Here are a few pictures showing where I am with the tear down. The red straps will hold the front end up when I drop the sub-frame.
Attached Thumbnails New clutch/flywheel-20161006_225946.jpg   New clutch/flywheel-20161006_230032.jpg   New clutch/flywheel-20161006_230054.jpg   New clutch/flywheel-20161006_230107.jpg   New clutch/flywheel-20161006_230124.jpg
Old Oct 14, 2016 | 07:43 AM
  #37
grussell's Avatar
grussell
All finished replacing the clutch. That was a big job with no reference material for the All4. The driveshaft removal was a pain in the ****. Then the transfer box has to be detached to get to a bell housing bolt, but can't be removed until the transmission is pulled away from the engine. It all went back together in about half the time it took to get apart. Surprisingly, the transmission went back on the engine first try.
Attached Thumbnails New clutch/flywheel-20161011_124902.jpg   New clutch/flywheel-20161011_125809.jpg   New clutch/flywheel-clutch-plate1.jpg   New clutch/flywheel-clutch-plate2.jpg   New clutch/flywheel-finished.jpg
Old Oct 19, 2016 | 05:56 AM
  #38
newman4333's Avatar
newman4333
Did something break or was it just the worn clutch disk?
Old Oct 19, 2016 | 06:35 AM
  #39
grussell's Avatar
grussell
The prior owner probably couldn't drive a standard very good. The clutch plate wears down to a point where the fiber material comes off leaving the metal to metal contact and no grip. That was my total failure I experienced.
Old Oct 19, 2016 | 10:32 PM
  #40
Mini Mania's Avatar
clutch flywheel
Wow, great job! You turned that around really fast. I am assuming you are up to speed on how much fluid is required. Here's an application guide if you would like some backup:
http://new.minimania.com/Search_Resu...on%20fluid/All
Old Oct 28, 2016 | 09:33 PM
  #41
DickieRich423
Well I am slightly glad I didn't buy the new clutch assembly yet. Unfortunately my baby was totaled due to a fresh on the road driver crushing the left front end while she was parked.
Had to switch to a family friendly vehicle(sedan) for the time being.
Sad sad day for T-Rexy
Old Nov 1, 2016 | 11:04 PM
  #42
Mini Mania's Avatar
Oh my gosh! So sorry to hear that.
Old Nov 14, 2016 | 09:14 PM
  #43
hidperf's Avatar
hidperf
I'm assuming that's the factory disc? I'm surprised to see an unsprung hub on an OEM clutch disc. Maybe that explains the dual-mass flywheel use then.
Old Nov 15, 2016 | 04:03 AM
  #44
grussell's Avatar
grussell
Yes, that is the factory disk in the pictures.
andrewjg1994
Sep 3, 2018 08:16 AM
N2MINI
General Mini related Ads
Feb 8, 2018 11:17 AM
smarsha11
Sep 18, 2016 08:49 PM
tretowrules
Aug 23, 2016 07:45 AM
TJANK
Aug 18, 2016 02:55 AM
