Drivetrain Fuel preassure r53
Old Apr 25, 2016 | 09:09 PM
slash695's Avatar
slash695
Fuel preassure r53
Hi guys and girls,
I'm troubleshooting a rough idle at the moment and decided to check fuel preassure. I got a gauge and hooked it up to the Schrader valve on the fuel rail.
These are the Psi I am getting.
Key on warm 55psi
Idle warm 42 psi
Revving in neutral 36 psi
It goes up initially under throttle then falls off to 36 psi at higher revs
I have a jan tune and 450 injectors, RMW cam, RMW headers and 17% pulley.
My spark plugs were showing lean.
Do you have to do this test under load??
I have just been throwing Money at this car trying to sort it and I'm almost out of options.
To make matters worse I recently started getting a ticking from the top left of the engine near the cam sprocket. Already changed the tensioner.
Cheers!!
Old Apr 25, 2016 | 09:25 PM
slash695's Avatar
slash695
Here is a video which may help
https://youtu.be/HuEaZxrVJQE
Do bigger injectors do that!? Thought it was meant to stay constant
Old Apr 26, 2016 | 12:24 PM
BlwnAway's Avatar
BlwnAway
I can't remember the actual numbers, but yes you have to check this under load, our cars use vacuum fuel regulators that are controlled by loss of vacuum and this will cause the FP to fluctuate with demand at the rail, where you're reading from. The pressure from the pump itself is still constant.
Old Jun 26, 2016 | 07:38 PM
David.R53's Avatar
David.R53
Fuel pressure/flow dropping under load is also a symptom of a plugged up fuel filter. Consider changing it out if you haven't done so already.
BlwnAway
May 20, 2016 12:07 PM
mikeyr
Classic Mini Talk
Apr 26, 2016 02:12 PM
randeez
Apr 1, 2016 12:11 PM
IQRaceworks
Mar 31, 2016 07:11 AM
devilmotorsports
Mar 29, 2016 01:35 PM
