Drivetrain Issues with my manic tune?
Old Mar 31, 2016 | 11:11 AM
Fiveostang's Avatar
Fiveostang
So I have been getting a hiccup and then a cloud of smoke from the tailpipe under hard acceleration occasionally. It doesn't do it everytime but enough that it's embarrassing when it happens and annoying. Has anyone else experienced this? I'm running a 2010 clubman with JCW intake, WMW catless, and helix intercooler on a stage 2+ tune.
Old Apr 1, 2016 | 06:41 AM
GAT's Avatar
GAT
i have the same issue under load. It was there before the tune but certainly more noticeable now with the extra boost. What you are experiencing is called SUPERKNOCK. Search NAM, there' a lot of info on this. It has to do with your fuel grade and pinging/detonation. Make sure you are using top tier fuel and 93+ octane. I always use top tier but I find that my MCS does not like Shell fuel, it causes more superknock than other top tier vendors. Exxon-Mobil seems to work better or you can throw some octane booster in your tank. I spoke with my Manic dealer and he suggested that I run colder spark plugs... I have yet to do so as I just changed plugs 2k miles ago to prepare for the tune. He recommends the Mitsubishi Evo plugs - NGK Iridium ILKR8E6 stock# 1422. Cleaning or blasting the carbon buildup off your intake valves is supposed to help as well, again, mine were cleaned 2k miles ago when I changed the plugs.
PS - you should notice a clicking or ratcheting sound coming from the motor when this happens. Let me know if you come across any useful info. Its driving me crazy. Definitely make sure to take my advice regarding the fuel. It helps out A LOT but unfortunately it does not eliminate the situation 100%.
Old Apr 1, 2016 | 07:09 AM
Fiveostang's Avatar
Fiveostang
Yea I only run premium in the car and have been using the evo plugs since it was tuned. I work for mini so I've had the carbon cleaning done here at my store. I also replaced the HPFP cause I thought that might be the issue. I'm going to drop it off with a manic dealer for a few days for some diagnostics see if they can figure it out.
Old Apr 1, 2016 | 07:58 AM
GAT's Avatar
GAT
I too had my HPFP replaced under warranty about 1.5k miles ago. Unfortunately I do not think Mini, or anyone else, has ever identified a complete fix to this issue. Given that its octane related I think that switching the Manic tune, to a Map that rated for 91 octane, may also help out quite a bit.
Please keep me posted on your findings and I will do the same. Thx bud.
Old Apr 1, 2016 | 04:46 PM
Tigger2011's Avatar
Tigger2011
Alliance Member
This can also happen when oil mist from the valve cover enters the intake tract. When this happens the effective octane rating can drop below 86 resulting in superknock. OCC on the boost side helps unless the valve cover is failing.
Old Apr 1, 2016 | 06:03 PM
thebombardier's Avatar
thebombardier
Have you checked the coil packs? One might be on its way out.
Old Apr 1, 2016 | 06:21 PM
Fiveostang's Avatar
Fiveostang
I will check both of those items. Whatever it is I want to get it fixed while I'm still under CPO
Old Apr 1, 2016 | 10:28 PM
MarioKart's Avatar
MarioKart
Vendor
Like Tigger said, we have seen lots of melted or nonfunctioning Valve covers. Might be worth it to replace with a new gasket and add Oil Catch Can OCC
mQubed Motorsport, Manic Tuning Dealer
Old Apr 15, 2016 | 07:54 AM
AFN704's Avatar
AFN704
Hold up.... your modded and tuned and still covered under warrenty? That would be awes9me if that's the case but I thought a tune pretty much sealed the deal with you losing coverage lol.
Old Apr 17, 2016 | 06:48 AM
sbninja's Avatar
sbninja
So you are having this issue when you are injecting meth?
Old Apr 17, 2016 | 08:16 AM
cerenkov's Avatar
cerenkov
"Legally" the modification (i.e. tune) has to be the cause of the malfunction for MINI to deny the warranty claim. That being said MINI can deny anything for any reason and you'll have battle it out in arbitration or court. Typically, MINI has deeper pockets than any of us.
Old Apr 17, 2016 | 08:53 AM
ZippyNH's Avatar
ZippyNH
Some dealers are mod friendly....
Know we have 2 in the area....good luck, but excess heat from a tune is possible... Might not even ask....
tmdflh
May 29, 2017 08:42 AM
bobjcw
Apr 3, 2016 05:28 AM
beemboy
Mar 14, 2016 11:10 AM
thebombardier
Tires, Wheels, & Brakes
14
Mar 10, 2016 02:57 PM
WayMotorWorks
Mar 3, 2016 09:33 AM
