Drivetrain Bigger CAI cone Filter??
Old Aug 2, 2004 | 09:25 PM
Arly's Avatar
Arly
Hello all,
I have a Cold Air intake from Mini Madness and would like to know if there is a cone filter from K&N or others that has a larger surface area than what Madness supplies with their kit. The tube diameter mus be the same as the madness cone.
Thanks.
ARLY
Old Aug 3, 2004 | 07:25 AM
sanddan's Avatar
sanddan
They use a S&B brand filter, just get on their website and get the size you want. Either a 7" or even the 8" filter will just fit. It will work better if you open up the plastic divder as this will let air into the end of the filter. You can use this link.
http://www.bakerprecision.com/sandb1.htm
Old Aug 3, 2004 | 08:23 AM
Arly's Avatar
Arly
Bigger CAI
Sanddam,
What diameter does the Madness intake tube have? Outside Diameter spec?
I already have the madness cowl opening mod. You mentioned that 8 in would fit. From you experience, what is largest and longest you have found to fit that area that madness takes up? I am going to take measurements before I order.
Thanks,
ARLY
Pker
Apr 11, 2017 12:14 AM
bADbOYbECK
41
Oct 16, 2015 12:39 PM
Alanberto
Sep 22, 2015 07:30 AM
thebombardier
Sep 15, 2015 02:53 PM
Sep 10, 2015 11:55 AM
