Drivetrain Turbo head shield?
#26
A turbocharger is a heat engine, keeping the heat in the hot side improves it's efficiency.
I work on large marine engines, all of them have insulation (lagging) on the hot side of the turbocharger. They do it for a good reason. I suspect that automobile companies don't lag the hot side of the turbocharger to save money.
One of the first things I did to my MINI was to put the WMW turbo wrap on it. It fits under the stock heatshield and is nearly invisible. The insulation has been there for almost five years, with no problems.
#27
#28
it is pretty easy to install. the hardest part form was to get the screws started on the front of the heat shield, I couldn't get my hand between the turbo charger heat shield and the radiator. I asked my wife to try it and she got it started with no problem.
One of the reviews of Way's turbo wrap says that they measured a 25 degree drop in under hood temperatures with the turbo wrap.
http://www.waymotorworks.com/wmw-turbo-heat-shield.html
My dealer has never mentioned it, when I've brought it in for service.
#30
#31
Oops, looks like the materials engineer in me slipped out!
#32
Any words of wisdom ? I am not understanding how heat really helps a turbo ? Does keeping the hot side hot make a difference ? I would like to reduce engine bay heat without causing any warranty or wear issues to turbo.
Anyone just use header wrap ? I like the alta idea but again it's over priced like most of their items.
M7Speed
R58 :: Coupé Talk (2012+)
09-03-2015 07:29 AM
M7Speed
09-03-2015 07:27 AM
