Drivetrain O2 simulator
O2 simulator
Can anyone provide more information on an O2 simulator for the Cooper S ?I have a Quicksilver exhaust w/cat and i am now getting the error code p0420 "catalyst system efficiency below threshold (bank 1)".I have less than 3000 miles on this exhaust and refuse to replace the cat.Does anyone sell them?Can i build one?Any info. would be greatly appreciated.
hI bISCH, i HAVE A 2003 COOPER S WITH 15% PULLEY, ALTA INTAKE, MAGNAFLOW EXHAUST AND i JUST INSTALLED A NEW HEADER 4-2-1 WITHOUT CAT AND MY SES LIGHT CAME ON AND THEN OFF AND ON AGAIN AND IS STILL ON. CAN YOU TELL ME IF THIS O2 SIMULATOR WILL WORK WITH THE COOPER??
iN THE LIST OF CARS THE DEALER SHOWS DOES NOT LIST THE COOPER AS IF IT WORKS.
THANKS YOU FOR YOUR HELP.
PS: I WILL DYNO MY CAR TO SEE WHAT KIND OF GAIN I GOT FROM THIS HEADER WITHOUT CAT. THE BUT DYNO SAYS THERE IS A LITLE MORE TORQUE ON IT. THE SOUND WITH THE MAGNAFLOW IS GREAT, NOT TO LOUD, WELL I HAVE A 65 MUSTANG 289 COBRA WITH HEADERS AND AND NO MUFFLERS STRAIGHT TO THE SIDES AND THAT IS LOUD.
:smile:
:smile:
Bisch,
Thanks for the info,i ordered one from the company you suggested.They said it would work on the Mini S with no worries.I can't believe the cost compared to other places wanting hundreds of dollars for theirs.Thanks again,and if there is anything i can do for you let me know.
Thanks Bisch, good stuff.
juzmackjr, reply back with the results of install I may get one for my other car which pass's the emissions test but fails because the light is on.
Originally Posted by Trippy
It sounds like something is broken.
A catalytic converter should last more than 3000 miles.
http://forums.vwvortex.com/zerothread?id=663057
I had a an ATP 3" cat in my GTI for over 20k with no problems at all. jlm is running the same cat in his MINI and thousands of miles later, no codes. Here's the cat in question:
http://www.atpturbo.com/Merchant2/me...ory_Code=VVWDP
02 Simulator results
You must understand that almost all aftermarket headers/exhaust systems use OBD I CATS. This is for two reasons, first the cost, and second the size. The O2 sensor downstream of the CAT is an efficiency sensor and OBD I CATS will not work in this system. Replace the CAT and your problem should be solved.
OH, by the way. There two different types of OBD II generic CATS. One is approved for 49 states and the other is approved for use in California. The California is a little more expensive but it is also suppose to be a little better and last longer. The California OBD II CAT is what I have in my car. Is it truly better then the 49 state one, I don’t know.
Dave
Dave
D1JL, thanks for the feed back but in this application with header there is no CAT. Would like to satisfy the ECU with 02 sensor simulater and leave the check engine light for other warning codes while on the track.
Good Luck, I have an O2 simulator it cost over $500.00. Although the CAT efficiency sensor is an O2 sensor it reads a different signal because of the CAT. An O2 sensor produces its own voltage that varies with mixture from .1 to .9 VDC and looks like a sinusoidal wave on an oscilloscope. The CAT efficiency sensor on the other hand puts out ALMOST a flat line at about .45 volts. The problem you are going to have is that the OBD II ECU not only checks for good or bad but also rationality. Remember that the output of the CAT efficiency will look just like the O2 sensor until the CAT gets hot. Then of course there the OBD II self tests and don’t forget the heater circuits.
Dave
Dave
Although I do have the Milltek, I'm afraid that it has eaten three rear O2 sensors.
I bought the O2 simulator in the thread above, but it rarely worked. We could never dial in the right settings. The ones that the manuafacturer suggested never worked.
Finally I just had to bite the bullet and buy another sensor. After 3000 miles, yet another rear sensor (#3 since I bought the Milltek header and catback) appears to have failed.
Not sure what to do now.
Anyone have an update about this product on single output O2 simulator for $25?
Does it work or not?
Or anyone try this from Pony Express for $20.95?
http://www.ponyexpressperformance.co...liminator.html
Seems now after about 1-2 years that many Milltek headers have trouble with the high flow cats and dash SES lights going on from error code P0420 "catalyst system efficiency below threshold (bank 1)"
Anyone find a reliable solution to this?
Switch back to a stock header?
Weld a stock cat to the Milltek header?
Switch to another aftermarket header (OBX on ebay) and weld a cat on that?
Please tell us about your successes.
Mab01uk
Nov 1, 2008 12:50 PM
