Drivetrain Clutch Question R53
Old Aug 19, 2014 | 09:02 AM
Discostu3169's Avatar
Discostu3169
R53 Compare
First post.
My clutch is completely gone and I am looking into upgrading to a performance clutch/flywheel. I was wondering if any one had any insight on either the Madness Stage 3(ACT manufacturer I believe) or the one I just saw on here from South Bend clutch; maybe the Stage 2 Street.
Thanks in advance.
Old Aug 19, 2014 | 09:03 AM
Discostu3169
R53 Clutch Question
First post.
Thanks in advance.
Old Aug 19, 2014 | 09:04 AM
Discostu3169
Clutch Question R53
First post.
Thanks in advance.
Old Aug 19, 2014 | 09:55 AM
ottawa's Avatar
ottawa
Make sure that its not your slave cylinder that is toast.
We wouldn't know since you just said it was toast, but just check.
In my opinion, do ACT street fly and OEM clutch.
You probably will never need anything over that unless you're pushing more than 275whp.
My stock clutch has lasted 45k miles at 255whp with out a problem. I plan on doing ACT street fly and OEM again. if you're going aftermarket, go big or go home. OS Giken clutch and fly.
Old Aug 19, 2014 | 11:25 AM
ZippyNH's Avatar
ZippyNH
Welcome....
Which "first post" is the first? When you cross post the same question (6 times I think)...folks tend to tune out...
More info is needed...
How will you use the car, any mods? If so, how much HP? Going with a lighweigh single mass clutch conversion?
south bend is new to the mini market....many HP clutches have come and gone....but the stock will do fine till 225-250 HP to the wheels.....
Old Aug 19, 2014 | 12:23 PM
Discostu3169
Yeah I posted from my phone, and kept getting error messages. I guess all went through. Right now I am completely stock but am looking for somewhere around 250HP when all said and done. I bought the car used and the clutch was iffy from the start. It is completely dead now. So I wanted to buy for my future mods and get the lightweight single mass/ beefed clutch since I'm going to be dropping the bad one out anyway. It will be a weekend only vehicle until I get some mods done, then I might look into some light track days, if I can find any in my area.
Old Aug 19, 2014 | 01:47 PM
astroBlackMetallic_Mini's Avatar
dude. stop posting 8 different ways. we all see your posts, but its nearly obvious you have done little to no research before posting the same thing so many times... possibly why nobody has bothered to answer. its annoying for one...
fwiw,
stock clutches are known to be great, and useable up to nearly 300 hp if i remember correctly. start going with those upgraded ones and you usually get "chatter" from the clutch / flywheel so ive read.
the higher "stage" clutch you go, the harder normal driving will be; you dont want to have to dump the clutch at 3 and 4k rpm to take off from a stop light every time.
if you must spend the money, go with a stock clutch and possibly a lightweight flywheel. if its not a daily driver and more of a race car, go for the staged clutch setups.
Old Aug 19, 2014 | 10:30 PM
miles_miles7's Avatar
miles_miles7
OEM is good for 250hp.
I'm on CMFX100 and steel flywheel and its a love and hate relationship. I love it on power pull and hate the combo on uphill stop and go.
Old Aug 20, 2014 | 05:18 AM
cristo's Avatar
cristo
Alliance Member
The Valeo kit is only a couple pounds lighter than the R53 OEM dual mass, but I like its feel (I have it on an R50), and it's supposed to be reliable and durable.
Old Aug 20, 2014 | 08:06 AM
Kahnfucious's Avatar
Kahnfucious
A few lbs is a lot when you are dealing with rotational mass... People go for lighter crank pullies on other cars to save a few ounces
Old Aug 20, 2014 | 10:03 AM
ZippyNH's Avatar
ZippyNH
True...
But on the mini the mass gives you a bit more tq when starting out...it is saved energy...but you end up with a less revvy car, but much better for hill starts and stop and go...
Like all things it is a compromise....
Roting mass can be saved on both the crank damper (false sense of economy IMO) and the flywheel....but go too light...and standing starts are tuffer...and some chatter...
Old Aug 20, 2014 | 10:15 AM
quikmni's Avatar
quikmni
I would also look at OS Giken GT clutch and limited slip (if you do not already have LSD).
http://www.waymotorworks.com/os-gike...-cooper-s.html
http://www.waymotorworks.com/os-gike...ntial-lsd.html
andrewjg1994
Jan 29, 2021 07:45 PM
eliseo1981
Jan 28, 2021 02:45 PM
Zettinger
Aug 25, 2015 04:04 PM
mini yellow-haa!
Aug 13, 2015 11:18 AM
Colt45Magnus
Aug 12, 2015 06:43 AM
