Drivetrain Wires and coil pack 0-60 times
Old Feb 22, 2007 | 04:16 PM
  #26
cartar452's Avatar
cartar452
Originally Posted by Dr Obnxs
then the plug is fine. Harder starting may be from the wrong gap. But I dont' really know there. Is it all back together and running?
It's raining now, or I'd just go snap you some photos.... If it clears I'll be happy to!
Matt
Thanks for all your help. I torqued the plugs to 24 lbs and it seems to be starting easier yet the connector on the back of the coil pack is still just sitting on there. I know how to get the red clip out but I can't seem to figure out how to get it to lock back in. Any advice?
Old Feb 22, 2007 | 06:01 PM
  #27
Dr Obnxs's Avatar
Dr Obnxs
With the tab OUT
put the connector back onto the coil pack. Press it down as far as it will go. Then press the orange tab back into the locked position. To be honest, I don't know if the plug will go on with the tab in the locked position or not. I never tried! In will "click" back into place, but shouldn't take a lot of force. If you find that you're pushing harder than you think you should, try pushing the connector a bit farther or pulling it out about a 1/16th of an inch and try the tab again. What's too hard? When it brakes!
Matt
Old Feb 22, 2007 | 06:59 PM
  #28
cartar452's Avatar
cartar452
Matt
hmm still can't get it to work...i took a few pics of whats goin on so maybe they will help...
it seems like the clip won't slide all the way in...any ideas??
Old Feb 22, 2007 | 08:33 PM
  #29
Dr Obnxs's Avatar
Dr Obnxs
It's not on far enough for sure...
but it looks like the tab is either out fine, or could use a bit more removal! Take the stock coil and the connector on and off that one. When you're happy with the motion there, you can then work on the new coil pack. I've found that sometimes the dimensions on cloned parts aren't perfect. It may just be tighter.
But it's a good rule of thumb to go back to what worked, get everything straightened out, then go forward again.
Matt
Old Feb 22, 2007 | 09:13 PM
  #30
cartar452's Avatar
cartar452
Matt
Thanks for all the help . I'll have to try this weekend to get it fixed as I don't have the stock coil here. I took the red clip entirely off and the connector still only went in as far as it has been. So I think I'll have to compare to the stock coil and adjust the new one to make it fit. I'll let you know how everything goes.
iggi
18
Feb 9, 2026 01:00 AM
Bublik
Feb 18, 2023 11:09 AM
W0TM8
Dec 19, 2019 07:50 AM
PrimePower
Aug 16, 2015 06:29 PM
yashmack
Aug 15, 2015 10:16 AM
