Drivetrain 15% to 17% Pulley Change
Old Apr 17, 2014 | 06:30 PM
purplehaze05mcs's Avatar
purplehaze05mcs
Can this change be done without lifting the engine again? Is there enough room to remove the existing 15% since a puller is no longer needed then slide in the 17%? Is it doable?
Old Apr 17, 2014 | 06:36 PM
xsmini's Avatar
xsmini
Might be possible, not exactly sure, would be tight though. I ended up just replacing the crank pulley with a 2% larger. Close to the same, and it is/ was a weak part on the early 53's.
Nik
Old Apr 17, 2014 | 07:41 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
It could be done, but would be much easier to just jack the engine up.
Old Apr 17, 2014 | 08:39 PM
purplehaze05mcs
Since I already have a 17%wmw that's why I was thinking if anybody has done it before. Also health wise I cannot do all those jacking up stuff anymore and also avoiding extra labor cost to install the smaller pulley.
Old Apr 22, 2014 | 01:12 PM
inimmini's Avatar
inimmini
I switched from 15% to 19% without jacking the car up - not hard at all.
cw40342
Oct 6, 2015 05:07 PM
sprp85
Aug 22, 2015 06:16 AM
FLYM1N1
Aug 16, 2015 01:17 PM
azntaiji
Aug 13, 2015 03:24 PM
