Drivetrain ra2fanatic's Wagner Competition Intercooler Impressions
Old Mar 31, 2014 | 07:23 PM
  #51
Phipu91's Avatar
Phipu91
I got an email back from Wagner and they only offer their intercooler in a black color. Oh well. Just gotta save for one 😋
Old Apr 2, 2014 | 05:27 AM
  #52
richardsperry's Avatar
richardsperry
Originally Posted by ra2fanatic
I can get my hands on a Helix, not an issue. Alta, Evolve? Oh, and Forge.
Anyone else I'd be missing?
Actually, I don't want the Alta, I don't want to do any modification to my bumper. lol
I didn't have to mod the bumper at all. I did trim a plastic support part, but it's cheap and easy to replace. ( but you don't have too...)
The Alta seems to work very well.
Old Apr 27, 2014 | 06:03 PM
  #53
67morris's Avatar
67morris
I got mine installed today along with NM boost tube. The bumper wouldn't fit right. I think some of the lower grill clips need to be trimmed. Kinda disappointing that I couldn't finish it tonight. Otherwise it seems to fit nicely.
My stock ic had a good amount of oil in there, so I am glad i did it.
Old Apr 27, 2014 | 06:07 PM
  #54
ra2fanatic's Avatar
ra2fanatic
Did you cut the top mounting tab? If you did it would totally fit perfectly with no trimming of the bumper.
Old Apr 27, 2014 | 06:28 PM
  #55
67morris's Avatar
67morris
Yeah, I did. I think it's the bottom grill tabs that need to be trimmed to allow the bumper to go a little higher and clear the sides of the ic. Otherwise, I am having a gap where the fender flare meets the bumper.
Old Apr 28, 2014 | 04:16 AM
  #56
JohnPlayer's Avatar
JohnPlayer
Mine is supposed to arrive today. It sure arrived fast from Germany. Can't wait.
Old Apr 30, 2014 | 06:31 PM
  #57
Phipu91's Avatar
Phipu91
I got my Wagner intercooler a few days ago and will be installing it tomorrow in preparation for my tune from Manic on Saturday. So far I can say the build quality looks a ton better than that of the Forge intercooler and am looking forward to my drive tomorrow. I'll update once I have a clear impression but so far I would recommend this over the Forge.
Old Apr 30, 2014 | 06:47 PM
  #58
Agbullet25's Avatar
Agbullet25
I wonder if this is just a difference between the stock front bumper and the JCW aero front bumper (and consequently the difference in lower grills)?
Old May 4, 2014 | 06:35 PM
  #59
67morris's Avatar
67morris
I had to trim a hell out of my grill today. Removed my JCW badge as well as it would not clear the lower sides on the new ic. I am sure it wouldn't be a problem with JCW bumper.
Old May 4, 2014 | 07:14 PM
  #60
Agbullet25's Avatar
Agbullet25
Stealth mode engaged lol
Old May 4, 2014 | 07:57 PM
  #61
67morris's Avatar
67morris
Old Jun 23, 2014 | 01:38 PM
  #62
Grizld700's Avatar
Grizld700
Heads up, I attempted to send a pm your way, not sure if you got either one I sent. It doesn't show up in my sent items folder. Just curious what exactly you had to trim to get the front bumper to fit over the competition intercooler.
Old Jul 23, 2015 | 07:43 PM
  #63
Indimanic's Avatar
Indimanic
Whatever happened to this thread. Would like to verify temp's with this IC.
Anyone out there have the Wagner competition IC?
Old Jul 24, 2015 | 08:36 AM
  #64
whrisk's Avatar
whrisk
i have the competition wagner IC. it works great. IAT used to raise 30 degrees in just a 2nd gear pull, now it only around 10 degrees for a 2nd through 4th gear pull in the florida heat.
i have an 08 so its a pre face lift front bumper. so i had to trim the front bumper a lot to make it fit. i had to trim so much i could not use the oem lower bumper grill, i had to order the M7 grills. so keep that in mind. if you have the older model R56 it would be a lot easier to go with the one that fits without having to trim and buy grills.
Old Jul 24, 2015 | 09:36 PM
  #65
squawSkiBum's Avatar
squawSkiBum
Moderator
I posted some install comments and measured data here: https://www.northamericanmotoring.co...ml#post4033467
Saw similar results at the track a few weeks ago.
Old Jul 25, 2015 | 09:16 AM
  #66
ridinDirty's Avatar
ridinDirty
I live in Vegas , it's been a hot summer . 100-117 on my mini dash. I use a scanGauge to monitor my IAT and compare it to my mini ambient dash temp.
Cruzin at highway speed it seam to take awhile to cool back down. I can't compare it to another cool due to the fact I only have this one .
When the meth kicks in and cools my IAT down the Wagner keeps it cool for miles.
I don't know if there is a cooler that can cool in this heat but you would think at 70-80 mph it would get the IAT within 4-6 degrees pretty quick with the "volume" it has .
I wish someone would test these things. I do feel like the winner wouldn't win by much, also I feel like who ever cooled the best would prob have a higher DP across the cooler and who ever had the less DP wouldn't cool as well.....
Just my 2cents
Old Jul 27, 2015 | 05:51 AM
  #67
Grizld700's Avatar
Grizld700
I can verify it does take a lot of trimming on my '07. But I did get it to work with a lot of time and care. I trimmed the grille down, checked, trimmed, checked, trimmed, ect, ect. This was done on my MCS bumper. My JCW also required a little trimming (less than my MCS) to fit flush.
I forgot to note this was the Competition model.
Qik420
Oct 4, 2015 08:19 PM
Tires, Wheels & Brakes
Oct 1, 2015 10:38 AM
Oct 1, 2015 10:17 AM
potterstein
Oct 1, 2015 07:10 AM
Adam Bradbury
Sep 28, 2015 04:15 PM
