Drivetrain ra2fanatic's Wagner Competition Intercooler Impressions
#26
One question, any fitment or install issues? I've got a MY2012 Cooper S, and am worried about the bumper and grill, and having to hack it in?
#27
#28
Cut the top tab that it comes with. It's completely not necessary and it'll sit nice and snug like the photo provided. If you do that, you won't have to do any bumper/grill trimming. I did this with my Forge intercooler when I had it. It holds nice and tight on the existing oem mounts just fine!
#29
I think it might have something to do with the cold chilly wet air we have been getting lately, in the sun it's warm but the second you're in the shade it's chilly! My MCS has hardly been running after turning off the engine at all, I have even waited for it to come on but it doesn't.
#30
#31
#33
Really? The comment was in response to your post directly above mine, and to this:
To say it more clearly: I don't think the time the radiator fan stays on has anything to do with your intercooler. It's based on thermostat temp, so it does stay on a shorter time in cooler weather as mentioned above.
#34
#39
Give them a call and see what they can do.
#40
yeah, I'm fairly confident I can do it, just more concerned that since I have the aero kit on, that it is going to get in the way more than normal. It looks like once the bumper is off, the intercooler swap is a piece of cake with two clamps.
#42
After reading reviews on other MINI websites i see that the Wagner Intercooler is very well liked, although a few people have posted data suggesting you lose 5 hp but get better temperature readings so it's a trade off i guess. Darn you Ra2, making my decision for a future intercooler even harder now!
#46
I saw someone's dyno on a motoring alliance thread, they did dyno with stock IC, Stock IC with tune, and Wagner IC with tune. Wagner IC with tune produced 5 less hp, but far better temperature readings.
#48
#49
Intercoolers do not really add or decrease power. They mearly make the power you do have more consistant. Yes you will see a pressure drop, resulting in a slight power decrease, but after driving it hard on the street, track, autocross, ect. you will have more power still being delivered since you will have cooler air temps going in compared to the stock. Plus if you get a tune, you will be limited in how aggressive the tune can be if you dont get an uprated FMIC.
Long story short. Dont worry about 5hp. You'll be fine.
#50
Hey,
Glad you have your new intercooler and are happy with it
I’m wanting to ask a couple of quick questions about what everyone is discussing here as I’m not quite sure I am keeping up
Pressure drop. How is this measured? Is it boost pressure before intercooler and boost pressure after intercooler when under full throttle/maximum power? The difference between the two is the pressure drop? Is this done on an actual car using a turbo, IE Hot side of the intercooler air pressure versus cold side of the intercooler air pressure? If that is the case, doesn’t the pressure drop because the air is colder? I am wondering if that is the case and if so, wouldn’t we want to see the biggest pressure drop between hot and cold side as that would be the same as the biggest temperature drop?
The test people talk about on other posts here is the “IAT recovery times”. I am not sure I understand this test either. Isn’t the measure of an intercooler its ability to maintain the lowest temperature possible when ON boost rather than when recovering after letting go of the throttle? Of course that would also be a benefit but I would think it’s more important to be measuring the temperature difference between intercooler inlet (hot side) and intercooler outlet (cold side) as this is when BHP is important, rather than how quickly the piece of metal cooled itself down when on cruise after the throttle is released?
I am always looking to learn more about intercoolers. We fitted something a bit different to my car. I think this picture link should work. It’s not by any of the major known names that mini guys use.
Regards,
Steven_RW
Regards,
Steven_RW
Last edited by Steven_RW; 03-31-2014 at 07:24 AM. Reason: My bad on the formatting..!
