Drivetrain 243whp 268wtq wirh JB+ on GP2
Old Dec 9, 2013 | 10:51 AM
  #51
ra2fanatic's Avatar
ra2fanatic
Originally Posted by TeddyL
I have a '13 JCW and am also getting the CEL. I can clear it with the CAN tool, but can't figure out how to actually read the code...
Any advice ?
http://n54tech.com/forums/showthread.php?t=20522
Old Dec 9, 2013 | 11:06 AM
  #52
TeddyL's Avatar
TeddyL
^ thanks! I've seen that but I'm having trouble actually reading the code...hmmm
Old Dec 9, 2013 | 05:10 PM
  #53
NewCooperFanatic's Avatar
NewCooperFanatic
I believe the boost cut limit is slightly higher for the JCW??
Could be wrong, I know 22psi seems to be the cut off for S cars.
But that's just too high for daily drivers, and such high CR's.
Old Dec 9, 2013 | 06:38 PM
  #54
calforhelp's Avatar
calforhelp
Originally Posted by MarioKart
There are many rumors about the difference of a JCW car and a regular S. But really the only differences
JCW 10.1 CR and 40mm turbo and a tune
S 10.5 and 37 turbo
GP2 10.5 CR and 40mm turbo and some advancements in cooling.
Ahh, thanks. Great explanation, makes sense now
Old Dec 9, 2013 | 07:44 PM
  #55
jomama's Avatar
jomama
the code reads out as hexidecimals. when you activate the can tool to read, the speedo needle points to the digit for each of the 4 character code (0-9 or A-F) 10 = 1, 20 = 2, ... , 90 = 9, 100 = A, ... , 150 = F.
hope that helps.
Old Jan 18, 2014 | 03:14 PM
  #56
Go-Cart's Avatar
Go-Cart
has anyone used dash command to clear codes?
Old Jan 18, 2014 | 08:26 PM
  #57
cerenkov's Avatar
cerenkov
It would NOT clear a P0420 code when I installed then removed a catless downpipe.
Old Jan 23, 2014 | 04:34 PM
  #58
bmx045's Avatar
bmx045
I have a feeling MINI didn't adjust the maf scale in the JCW map with their JCW intake and the DME is correcting for the added flow(they expected this small correction to happen). The JB+ will exacerbate this and cause it to reach(and probably bypass) a correction limit to throw a 0170 code. Simply hiding a 0170 system lean condition code is horrible advice IMO and doesn't fix the problem. That's not a code you want to be driving around for months and years unless you have factual data to prove AFR's are still safe(I.E. wideband o2). I know countless people who learned this lesson the hard way in various vehicle platforms in my tuning experience. The JB4 is a better idea since it can control a bit better.
Old Jan 24, 2014 | 01:30 AM
  #59
robbo mcs's Avatar
robbo mcs
What do you mean "with their JCW intake". The factory JCW air intake is the same as the cooper S intake, identical in all respects, same part numbers etc.
Old Jan 24, 2014 | 01:38 AM
  #60
MarioKart's Avatar
MarioKart
Vendor
Very true. I just noticed my 2013 GP is just like a normal S.
Sent from my iPhone Office
Old Jan 24, 2014 | 03:51 AM
  #61
bmx045's Avatar
bmx045
That is fascinating. I remember reading that the jcw intake was suppose to be slightly freer flowing than the S. Mini certainly markets it as an upgrade part. The only other thing that i can think of is the header being different, and I'm trying to figure out why the JCW's want to run leaner than the S's.
Edit: I was inadvertently referring to the 07-10 JCW intake which flows better.
Old Jan 24, 2014 | 07:57 AM
  #62
NewCooperFanatic
Yup! 07-10 had this
http://www.waymotorworks.com/jcw-int...6-r55-r57.html
Now all the n18's just have a panel filter, regardless if it's an S, JCW or even GP
Pker
Apr 11, 2017 12:14 AM
minimofo
Jan 26, 2016 11:32 PM
OutMotoring
Nov 16, 2015 07:04 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
cinq
GP Talk
Sep 14, 2015 05:32 AM
