Drivetrain r53 Tuning Options
#26
#27
RMW is based in socal, you could setup a time and just drive out and get tuned. Doesn't need to be a tune party.
#29
Rmw tune.
Call jan and he will explain everything. It really is your best option. There are many of us with 250whp to 350whp without any issues. The tune wont have to much timing causing overheating issues like ALL of the canned tunes. The jcw tune is meh.
There is the self tune method. But I've read so much about cars melting pistons.
Wildcards are paw motorsports in miami. And jb+ tunes.
I run rmw tune and parts. Could.not.be.happier.
http://www.revolutionmotorworks.com/...3&product_id=3
I've loaded a shopping cart many times and intended to buy this, just need to determine the whole process involved before making the purchase.
Best,
Ian
#31
Ok the tool that is sold by:
RMW and Way Motor Works is the DimSport programing box.
It does NOT come loaded with a tune, it is used for Remote Tuning and/or for those that have multiple tunes for your car. Example I had my car custom tuned I have 5 tunes in my programmer:
Stock
Stock w/380cc Injectors
Basic Tune w/380cc and Cam
Custom Tune no Meth/Water
Custom Tune WITH Meth/Water
The box is locked to your Vin/DME once you connect it and download your stock DME/ECU programming.
If you buy the box on its own it is worthless to you!
Now if you buy the box and a remote tune from the seller, download your Stock Flash, and send that off to the Tuner, they can send back a Tune that is setup for your car and after market parts, this will not be a true CUSTOM TUNE, but it will be close usually within 5 to 7% of a full custom.
Now if you take the car to a local dyno that has an O² sensor, you can send the information back and a complete Custom Tune can be created and then you load that into the DimSport Box and then re-Flash your DME.
Stock
#32
i'm interested in this as well... will be following this thread
08-12-2015 01:24 PM
