Drivetrain Oh yeah, that's right baby, I'm 19%....and lovin' every minu
Old May 2, 2004 | 01:46 PM
Bisch's Avatar
Bisch
I finally got my 19% on after taking my 15% off. I was able to do it without lifting the motor. I sure wish my fingers were smaller. What a pain in the pumpkin! Try removing a 1" screw, in a 1" space, with a 1" long hex wrench!
But boy does that baby whine now! From the sound, you would expect to see a blown Chevy with a big blower popping up through the hood!
I used the Goodyear Gatorback belt too. I'll put up pics of my shredding NAPA belt as soon as I can find my digital camera (it's packed, I'm moving).
Old May 2, 2004 | 01:48 PM
andy@ross-tech.com's Avatar
andy@ross-tech.com
Does this mean the clunk is fixed?
Old May 2, 2004 | 02:07 PM
Bisch's Avatar
Bisch
No sir. The clunk is no fixy. The only thing I could find is a lot of play in the axles. The axles have about an 1/8" or less of play in and out of the wheel (length-wise) and a little slop rotationaly. I'm thinking that's not a good thing. The dealer did have my tranny apart for the clutch bearing about 600 miles ago...hmmm.
Old May 2, 2004 | 05:07 PM
CCM's Avatar
CCM
Tim, You rat. This competition will get me a blown engine soon! I'll be in Hyanus later this week to visit. I'm in Truro all week but will make the drive up with the MINI to visit and to have a listen. We'll should have a shoot-out up towards Mary Dunn Road near the CC chip factory. Your 19%, headers and Magnaflow vs. my 15%, AmD Oneclick and Nitrous.
Old May 2, 2004 | 05:44 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
I'd put my bet on the 19% with exhaust system. You need an ECU though.
Nitrous doesn't last forever. The 19% is scary fast.
Old May 3, 2004 | 04:09 AM
CCM's Avatar
CCM
I've got the ecu reprogrammed with my AmD one click. Tim has had a nitrous ride with me so he knows what that feels like :smile:
Old May 3, 2004 | 04:52 AM
jlm's Avatar
jlm
the nitrous will whomp-***.
Old May 3, 2004 | 06:57 AM
Bisch's Avatar
Bisch
I won't tell CCM when I put nitrous in mine...I'll let it be a surprise!
As jlm said, the nitrous makes it a whomp-*** car.
Old May 13, 2004 | 08:00 AM
Bisch's Avatar
Bisch
Just to follow-up on the clunk:
The tranny was busted, and the wheel bearings shot. New tranny, new bearings and I'm off....
Old May 13, 2004 | 08:02 AM
andy@ross-tech.com
Youch! Any indication of what caused the tranny bustage?
Old May 13, 2004 | 08:04 AM
Bisch's Avatar
Bisch
ummmm, ahhhhh welllllll, hmmmmm. I think I'll PM you.
Old May 13, 2004 | 11:36 AM
MrWhoa's Avatar
MrWhoa
Hey Bisch, two questions.
1. How much Mr. Goodyear do you have to be to swap from the 15 - 19%. I mean it's just cramped space, belt tensioner, cramped space, drop hex bolt, curse etc right?
2. Does alta make a 19% pulley to fit on the hub type pulley yet?
Hell... I lied...
3. Since you appear to be a man of the transmission, ever heard a very slight, short metallic chirp when letting the clutch out in first? I have been hearing this for about 1 month now and NOBODY seems to have any thoughts on it.
Old May 13, 2004 | 12:03 PM
Bisch's Avatar
Bisch
>>Hell... I lied...
I have very big hands. (that's right ladies :smile:
Old May 13, 2004 | 12:07 PM
andy@ross-tech.com
Replacing a pulley without lifting the engine is one of those things that I'm glad I did but am not looking forward to doing it again. It inspires delusional fantasies of trained mice doing the job handily.
Old May 13, 2004 | 12:17 PM
Bisch's Avatar
Bisch
During the job, I realized the perfect tool would be this:
A very low profile air wrench with a very short hex bit. I wonder if it is made?
Old May 13, 2004 | 01:22 PM
MrWhoa's Avatar
MrWhoa
>>The chirp is probably the clutch throwout bearing. I had mine replaced two months ago, then I just wrecked the whole tranny :smile:
Crap... Well Im going to the dealer tomorrow... 258 miles... I dont suppose that is something easy to check... Hopefully they will know the noise, as it's easy to replicate. How long did it take them to do that job, the bearing I mean.
Old May 13, 2004 | 02:02 PM
Eric_Rowland's Avatar
Eric_Rowland
Your dime, or MINIs??
Old May 13, 2004 | 02:30 PM
gravedgr's Avatar
gravedgr
Old May 13, 2004 | 03:00 PM
Mini03Tiger84's Avatar
Mini03Tiger84
Lifting the engine is not that big 'o deal, especially if your just lifting to replace already replaced pulley. It would probably add an extra 30 minutes to entire job and you'd save your knuckles. Just remove the upper strut ( and few other bits along with it), the upper mount nut and the lower motor mount bolt and jack away.
Old May 13, 2004 | 03:10 PM
Bisch's Avatar
Bisch
The tranny was discovered to be a component failure...warranty. It was not a result of modifications to the vehicle.
The throw-out bearing is a whole day job. small part, big job.
Old May 15, 2004 | 07:44 PM
chigh's Avatar
chigh
I'm told that chirp is from the clutch.
For more info, contact Charlie at RDR Dyno. He's
tested his own MCS with the 15" and 19" pulleys
and done clutch, LSD, and flywheel changes.
Old May 17, 2004 | 01:55 PM
samawil's Avatar
samawil
Is the chirp only present from a dead start? Ie if you give a little too much gas and let go of the clutch you hear the chirp and basta? Or do you hear it all the time?
L
Old May 18, 2004 | 04:43 PM
Bisch's Avatar
Bisch
Just spent the day at the dealer getting the steering column replaced....only to find out that the new one is defective! Back I go next week.
Thank God for a warranty, but this is crazy.
Old May 19, 2004 | 05:44 AM
norm03s's Avatar
norm03s
null
Hey Bisch, hows that Goodyear Gatorback belt holding up? Could you post the part number/size for it here as it should work with the 17% too.
Old Jun 2, 2004 | 11:52 AM
Bisch's Avatar
Bisch
Sorry for the delay....
Here is my rusted pulley and shredding/cracking NAPA belt:
