Drivetrain JCW exhuast cutting? WHY?
Old Mar 23, 2013 | 07:19 PM
M'Cooper's Avatar
M'Cooper
Whats the reason that it has to be cut and then clamped? Im not aware of the set up under there but why isn't it just a bolt on type catback. I see this seems to be the case for most of the exhausts systems tho and I was wondering if someone can explain this. It just seems cheap for what the exhaust actually costs. Expecialy when being done at the dealer.
Old Mar 23, 2013 | 08:46 PM
borderwave2's Avatar
borderwave2
The stock exhaust after the downpipe is one solid pipe. The muffler, resonator and secondary cat are all welded into place. It's almost completely straight.
Old Mar 24, 2013 | 04:46 AM
M'Cooper's Avatar
M'Cooper
Oh ok, that makes sense now. It seems the clamps from Mini look durable and even the ones from the aftermarket set ups look sturdy. I just was concerned about it holding up. Thank you for clearing that up.
Old Mar 24, 2013 | 05:15 AM
Creeve's Avatar
Creeve
Just get the factory JCW exhaust if you don't want to cut. More expensive but its DP back.
Edit: NVM it appears to come in two pieces as well. Just has no catalytic converter.
Old Mar 24, 2013 | 07:32 PM
Shoof's Avatar
Shoof
Pretty much any exhaust you plan on installing will require you to cut the stock pipe.
Old Mar 25, 2013 | 12:09 AM
bmwr606's Avatar
bmwr606
milltek makes DP back exhaust systems for minis
http://www.millteksport.com/index.cfm
i have one on my cms all4
scott
Old Mar 25, 2013 | 05:54 PM
M'Cooper's Avatar
M'Cooper
Thanks for all the info, I was speaking with the SA at the dealer today about this. I may just go with the JCW one when I get to it for warranty reasons.
Old Mar 28, 2013 | 04:30 PM
richardsperry's Avatar
richardsperry
What warranty issues? It's a catback, it won't affect the warranty at all.
kazyn
Oct 25, 2019 02:34 PM
Chasp
Aug 22, 2015 01:26 PM
Overpolished
Detailing 101
15
Aug 21, 2015 07:19 PM
PelicanParts.com
Aug 14, 2015 11:07 AM
