Drivetrain Whose tubes to buy, Alta or MiniMania?
The R56 is fresh out of warranty and I'm thinking about installing a turbo inlet tube and a hot side boost tube. (The car has the JCW cold air intake already installed.)
These tubes are available from both Alta and MiniMania and the prices are fairly close. Other vendor options? Which ones to buy?
What can I expect from these parts? Alta ascribes 10HP to each = 20HP! Wow, really?
Any nasty engine malfunction lights and CPU indigestions?
Experiences, recommendations?
Thanks all.
Thanks all.
the r56 is fresh out of warranty and i'm thinking about installing a turbo inlet tube and a hot side boost tube. (the car has the jcw cold air intake already installed.)
these tubes are available from both alta and minimania and the prices are fairly close. Other vendor options? Which ones to buy?
What can i expect from these parts? Alta ascribes 10hp to each = 20hp! Wow, really?
Any nasty engine malfunction lights and cpu indigestions?
A tube won't give you 20hp. Ridiculous claims...
Thanks all.
Thanks all.
Large intercoolers are heavy, costly and require cutting to fit.
Catless downpipe sounds great but is it not too loud and won't it throw engine codes?
Catless downpipes are not loud, but it will throw a code, if you are not tuned.
Correction, Alta has some slight cutting. Helix and Forge no cutting.
IMO, get the hot side boost tube and Helix or Forge I/C and get a tune. You'll see increases for sure. Now the DP is a different story, if you have a manual, go for it if you decide to modify your exhaust system, if you're not going to modify the exhaust then forget about it.
On an automatic, I think the DP is pointless, it gets WAY to loud inside the car.
IMO, I wouldn't even put a DP on an auto cause I'd still be stuck at a Stage 1 tune from NM and RennTech said they would cut the power lower-mid so that the car wouldn't blow it's transmission. But everyone has a different opinion. I will stick without the 8-10hp it would produce for my auto. But if you like it, good, let me know how beastly it will sound after a tune.
Sorry for high-jacking the thread.
My buddy had a Riss racing catless on his auto, sounded like crap inside his car. A high flow cat will keep it down a notch.
Sorry for my role in the high-jack. Back to tube talk!
tubes won't buy you much
heres my thread on tubes
btw aftermarket IC's are alot heavier than stock,however they are bigger and should cool off better in hot situations , and they should have better internal flows too.
https://www.northamericanmotoring.co...and-hoses.html
The "MiniMania" tubes are actually from NM Engineering.
Sounds good. I wasn't aware of the Helix or Forge intercoolers and the Alta requires trimming which is why I thought about staying away from them.
To those asking why or how I came up with these mods the answer is that on a few cars that I've modded in the past the tubes brought about some improvements, albeit minor ones. Other cars did not respond at all or responded with ECU confusions.
Thanks for the input guys.
My other question to you is what year is your MINI?
Aug 25, 2015 09:18 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
