Drivetrain Weird whistling sound after Magnaflow Catback installation
Old Jan 23, 2013 | 09:27 PM
Brian Jarvis's Avatar
Brian Jarvis
I recently had the Magnaflow 2.5 in catback installed (part #16815) and ever since I've noticed a whistling sound or the sound of air escaping or not getting somewhere. So i had it check for leaks and they couldn't find any so i took the mechanic for a ride and he said thats the back pressure from the catalytic converter. I've also noticed a drop by about 5 mpg's which I'm sure is not normal. Has anybody else noticed this? Or could tell me what it is.
Old Jan 23, 2013 | 11:18 PM
Brian Jarvis
Also the sound only occurs while driving and stepping on the throttle, noise starts at around 3,000rpm and gets louder from there. Does not make the sound while standing and just revving the engine
Old Jan 23, 2013 | 11:23 PM
Cheerio44's Avatar
Cheerio44
Has it been going on for a while? The 5mpg might just be the heavy foot from wanting to hear the exhaust :P How many tanks have you gone through after installing the exhaust? Was the exhaust the only thing that was added/changed before it started making the whistling noise?
It could be a couple things, if you can you should check all the connections on the exhaust, make sure they're nice and snug.
Edit: took out the bit about the header, lol, just noticed this was from a 2nd gen car...
Old Jan 23, 2013 | 11:41 PM
Brian Jarvis
It started making the noise the day it got installed I've gone maybe through one tank of gas if that. I had the connections checked and their snug, it's the only modification to the car so far I'm waiting for a CAI to come in. It also doesn't make the noise while the car is cold, usually by the time I hear the pop and burble of the exhaust is when it starts whining.
Old Jan 24, 2013 | 05:38 AM
mikeyb74's Avatar
mikeyb74
I would check the clamp/gasket from the dp to the cat back. Also check the pipe fittings to make sure they are fitted correctly. Mine did the same thing and I found the clamp wasn't tighten enough.
Old Jan 24, 2013 | 06:57 AM
axleR56's Avatar
axleR56
I saw somebody say in another thread that you need to use a 1/2inch drive to tighten all the connections because a 1/4inch won't give you the necessary torque. Not sure if that applies to you but it's worth a shot.
Old Jan 24, 2013 | 06:01 PM
Brian Jarvis
Il check the clamps this weekend when I install the CAI and hot side tube
Old Jan 29, 2013 | 12:16 PM
ragingMINI's Avatar
ragingMINI
I have the same exhaust and I started noticing something very similar once I had a restonator put back on. It was clamped on, so I'd have to say that my first guess would be to tighten the clamps. I haven't been able to check my clamps as I don't have a garage and it's winter... ugh.
Old Jan 30, 2013 | 03:44 PM
Brian Jarvis
My CAI isn't coming in for another two weeks :/ so il just have to check then I don't feel like splitting up the work
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
makg
Aug 21, 2015 02:49 AM
Colt45Magnus
Aug 13, 2015 11:18 AM
