Drivetrain Venturi Scoop info?
Old Apr 2, 2004 | 06:15 AM
MSFITOY's Avatar
MSFITOY
Does anyone have one of these?
If so, I'd like your opinion. Any pics from various angles would be greatly appreciated
Old Apr 2, 2004 | 06:23 AM
andy@ross-tech.com's Avatar
andy@ross-tech.com
Anyone who gets one is welcome to borrow my Magnehelic differential pressure tester. I'm curious to see if it has any effect on the air pressure going into the intercooler at speed.
Old Apr 2, 2004 | 06:45 AM
trplezero's Avatar
trplezero
Ive got one.. i have had it on the car now for about 3 weeks... i like the look of it... although its kinda noisy at high speeds.....
Old Apr 2, 2004 | 06:55 AM
MSFITOY's Avatar
MSFITOY
I'm seeing a "x". Noisy? What kinda noise?
Old Apr 2, 2004 | 07:02 AM
trplezero's Avatar
trplezero
Like a wind noise... like the air is rolling over the scoop.. but this noise really is not loud until you reach 80 and up...
Old Apr 2, 2004 | 07:09 AM
MSFITOY's Avatar
MSFITOY
Really would be nice you could manage to put up the pic again
Old Apr 2, 2004 | 07:24 AM
trplezero's Avatar
trplezero
i was trying to.. but it was acting up.. these are on my cardomain site...
Old Apr 2, 2004 | 07:25 AM
trplezero's Avatar
trplezero
if you want anymore pics up close i can take them later... and post them... hope this helps...
Old Apr 2, 2004 | 07:31 AM
MSFITOY's Avatar
MSFITOY
Wow
Old Apr 2, 2004 | 07:34 AM
trplezero's Avatar
trplezero
its the great fix it tool... DUCT TAPE>. lol
nah its 3m two sided tape that came on it..
i will post the pics in about 2 hrs
Old Apr 2, 2004 | 07:46 AM
andy@ross-tech.com
Thanks for posting the pics. I take it the double sided tape is only on the scoop, not on the metal hood? Do you feel it was worth the price?
trplezero's Avatar
trplezero
i hope these have helped you....
Old Apr 2, 2004 | 08:29 AM
andy@ross-tech.com
Good pics, thanks!
MSFITOY's Avatar
MSFITOY
Thanks so very much These really help. I'm gonna order one today.
Andy, what is a "Magnehelic differential pressure tester"?
Old Apr 2, 2004 | 08:36 AM
trplezero's Avatar
trplezero
i like it.. it makes me different right now.. cause most people would not put that on there car because of the price... I think it cools my car down more with that scoop on there... although it probably only took 15 bucks to make i think this its worth the price..
Old Apr 2, 2004 | 09:11 AM
andy@ross-tech.com
MSFITOY,
The Magnehelic is a gauge that measures air pressure with very sensitive resolution:
https://www.northamericanmotoring.co...amp;topic=8631
Old Apr 2, 2004 | 09:31 AM
10851CS's Avatar
10851CS
My error I thought you said HIGH speed.
Earl
Old Apr 2, 2004 | 09:32 AM
zfxr's Avatar
zfxr
MSFITOY dang, keepin at it with mods
Old Apr 2, 2004 | 09:33 AM
trplezero's Avatar
trplezero
well i have been been known to bury my speedo... a few times... nothing like cleaning out the pipes... lol
Old Apr 2, 2004 | 11:24 AM
MSFITOY's Avatar
MSFITOY
Just tryn to feed more air into that big expensive Alta TMIC
Old Apr 2, 2004 | 11:25 AM
MSFITOY's Avatar
MSFITOY
I'd be willing to give it a try. Is it hard to set up?
Old Apr 2, 2004 | 11:29 AM
andy@ross-tech.com
Not hard to set up at all. It's just a gauge with two hoses attached to it. Tape one hose in the scoop area, seal off the other hose. Go for a drive. Record the reading at, say, 60 mph. Then, install the "venturi scoop" and go for another drive. Record the reading at 60 mph. If the air pressure is higher, the scoop does something. If it's the same it does nothing. If it's lower, it does negative something.
Old Apr 2, 2004 | 12:28 PM
Bisch's Avatar
Bisch
MISFIT,
Let us know how you make out with the magne-do-hicky-thingy. I'm real interested in the results too.
Old Apr 2, 2004 | 12:54 PM
flyboy2160's Avatar
flyboy2160
thanks for posting the pictures.
a little oversimplified aero: the noise you hear could be excess air spilling over the inlet. at any given air speed, you can only generate a given maximum static pressure that will force the air through the ic. the max amount of air that will flow through depends on this pressure and the resistance of the ic. having a larger inlet that captures more than the max amount that can flow through the ic means that the extra air just backs up and "spills" out of the inlet.
this spilled air is messy. on jet aircraft inlets, this messy spilled air causes what is called "spill drag." it's an ugly phenomenon that you are admonished to avoid. some designers try to avoid it with inlets that can change in size depending on the speed.
or you could be hearing vortices that are being generated off the back side of the lip, even if you aren't spilling.
ok, off the lecturn,
looking forward to somebody pressure testing/tufting these things,
flyboy2160
Old Apr 2, 2004 | 03:24 PM
MSFITOY's Avatar
MSFITOY
Andy, please check you PM. I will send you my address...ok?
