Drivetrain Venturi Scoop info?
>>i like it.. it makes me different right now.. cause most people would not put that on there car because of the price... I think it cools my car down more with that scoop on there... although it probably only took 15 bucks to make i think this its worth the price..
15 bucks? I thought this piece is made of real carbon fiber?
carbon plastic... is the composite material.. but i do have a BFP silver carbon fiber scoop that i took off to put this thing on because i didnt want to ruin it.... This probably took about 5 bucks to make, if you want to know the truth of the matter, if that much...
>>I must have missed the price quote somewhere
>>How much is it ?????
>>Peace,
>>D
It's around $160...way expensive...but considering the market for these doo hickies...we're lucky they exist at all. Good thing also, my wife like to keep me happy and allows my poor spending habits...better than doin drugs as Leno says
>>Peace,
>>D
If your going to get a scoop spend the extra money and get a real carbon fiber one, the "carbon look" version like the one trplezero has are functional but are made from abs and tend to flex and vibrate at speed which doesnt help the noise factor and will work the adhesive tape loose. The real carbon versions are very strong and tend not to have the problems of cheaper versions. There where a couple of write ups comparing the two on the mini2 site.
FYI, we're going to be making a full Carbon fiber version of this for MINI Mania to sell... Price should be about the same.
-DanB
www.benferperformance.com
-DanB
-DanB
-DanB
Originally Posted by JCampos
I am actually looking into having a custom scoop built from fiberglass.... ill let you know if it ends up happening or not.
Yup. The venturi suffers cuz it really doesnt open it up anymore... it just tries to cram more air into the same small space. The scoop has a good inch or 2 that can be used to cram more air in there that isnt utilized. There is a shop in my area that does good fiberglass work (made his own custom wing and splitter) that I contacted about doing this. No reply yet
Will you offer it painted? I really dont like the carbon ricer look
-DanB
BBR makes a scope as well. I believe they were one of the first. They claim it lowers the intercooler ten degrees at 60mph I believe. They are pretty serious tuners, so I am assuming that they have tested it.
I did enquire this venturi scoop from mini-design about few month back. They told me that the ones that they have fitted cause so much air turbulance that it causes the wipers to go crazy at any speed over 40 mph so be warned. If I'm not mistaken, they fitted it on the Dark Grey MCS in GOMINI Magazine Aug/ Sep Issue.
They got it from BBR and I also believe that BBR is one of the first.
I honestly think the venturi scoop is a waste of money. It doesnt open up the scoop any, just forces more air into the stock area that wants to be forced in.... causing turbulence and PROBABLY causing a loss in actual airflow to the intercooler.
I would like to see a piece that replaces the entire factory hood scoop, not just sticks to the top of it. If I can get a few people together to commit to a buy I am sure many people would consider creating one.
Any takers?
Any takers?
I have the BBR scoop and although I don't actually feel any power difference, the scoop didn't cause any turbulence in my case. Actually when I initially installed it I noticed that I sort of lost a little power, but I'm not sure since when I took it off again, it didn't feel any different. So now it's back on, I just like how it looks, I think it blends in better to some colors than others, plus I had mine painted.
