Drivetrain Dyno MCs r56 just 150 hp?
Old Nov 17, 2012 | 10:25 AM
Urke's Avatar
Urke
I have a problem. My stock MCs, cant produce more than 150hp.
All the parameters are ok, no problems on computer, turbo 0.9 bar.
Did anyone had the same problem? What to do?
thanks
Old Nov 17, 2012 | 11:56 AM
submitaweasel's Avatar
submitaweasel
150whp? Sounds about right.
Old Nov 17, 2012 | 01:54 PM
bratling's Avatar
bratling
Super Moderator
Yup. The advertised power is measured at the crankshaft. When you put it through the transmission and driveshafts, you lose a lot by the time it actually turns the wheels. 15-20% drop from engine to tires is typical. (15% is really good, actually. You're unlikely to see that anywhere but chain- or belt-drive motorcycles and other vehicles with very simple and light drivetrains.)
Old Nov 17, 2012 | 03:35 PM
Urke's Avatar
Urke
This is on crankshaft, not on wheels! Other frinds had 167 to 175 hp at the same time in dyno.
Old Nov 17, 2012 | 03:43 PM
submitaweasel
All bone stock?
Old Nov 17, 2012 | 04:12 PM
ZippyNH's Avatar
ZippyNH
You took the MOTOR OUT of your car to dyno it?! and disconnected the transmission!!!
some dyno's run on rollers under the tires, others run by bolting to the wheel hub.....
Outside an engine builders shop, a crankshaft dyno is VERY rare, and hard to use on a modern electronic controlled motor.....all the stuff must be taken out and connected on the dyno....lol..no car body!!
Bet the others had a few mods...and remember..there has been a motor change on the MINI...so year matters, FUEL matters, and current MX matters...have the valves ever been cleaned? Fresh oil? clean air filter? recent spark plugs? And the HP sounds like the important number...but tourque is the REAL number that makes a car fun to drive.
Old Nov 17, 2012 | 05:51 PM
countryboyshane's Avatar
countryboyshane
Still kind of a little weak at the wheel...
Old Nov 17, 2012 | 10:48 PM
Ta87's Avatar
Ta87
Depends on the dyno as well. If it's calibrated higher, it'll produce higher numbers. The same car can produce different hp results on two different dyno's in the same room.
Old Nov 18, 2012 | 02:00 AM
Urke's Avatar
Urke
The spark plugs are new, airfilter clean, gasoline 100 octane, fresh oil,...
Dyno is accurate, becouse on other minis they were 167 to 175hp, and they are stock. My is 2007 and others are from 07 to 09. I thinks the difference iin hp is to big.
Old Nov 18, 2012 | 02:37 AM
rkw's Avatar
rkw
How many miles on the car? Maybe carbon buildup on the valves?
Old Nov 18, 2012 | 06:13 AM
ZippyNH's Avatar
ZippyNH
+1
Fuel, and miles and how the car was treated means tons...and an '07 is first year of the "prince" engine production....know quite a few that got tebuilt motors swapped into them after only 6 months....drivers said they were never the same...couple traded to a r53 to wait till the bugs ...timing chain, and valve carbonization issues being the biggest were worked out....
oldest car, lowest hp is not that uncommon..
Old Nov 18, 2012 | 06:46 AM
cmt52663's Avatar
cmt52663
If you've someone you trust, a thorough compression check might shed some light on things.
If it were mine I would look into it, as any slight problem with compression could be cheaper to address now than in another 10,000 miles.
Bad or uneven numbers could point to a carbon problem affecting the ability of the valves to seal properly, or even a bit of ring wear.
Just a thought.
Cheers,
Charlie
Old Nov 19, 2012 | 09:29 AM
Urke's Avatar
Urke
It has 100 000 kilometers or 63000 miles. I was at mechanic today, hope he will find a solution. I gave him your informations...
Old Nov 20, 2012 | 09:29 AM
Urke's Avatar
Urke
What about catalysator? Did anyone had a problem?
Old Nov 20, 2012 | 09:44 AM
countryboyshane
You would have a check engine light for a badly plugged cat. Like others have noted, I would be checking the intake ports. They are probably full of carbon buildup.
ewu's Avatar
ewu
Also don't forget potential boost leak, clogged cats, or bad A/F (could be due to o2 sensor).
Old Nov 20, 2012 | 09:50 AM
MiniMoic's Avatar
MiniMoic
+1
Run a smoke test, maybe a nutshell blast too.
Old Nov 23, 2012 | 09:51 AM
Urke's Avatar
Urke
We solved a problem! It was carbon buildup! Now car goes faaasstt
thanks!
Old Nov 23, 2012 | 10:18 AM
Dark's Avatar
Dark
.9 BAR? I thought stock boost was 16+psi (1.1 BAR)
Old Nov 23, 2012 | 10:23 AM
MiniMoic's Avatar
MiniMoic
thanks!
You see!!? Toldya, nutshell blast!
Good to know its fixed-
Old Nov 24, 2012 | 12:53 PM
cmt52663's Avatar
cmt52663
thanks!
Old Nov 24, 2012 | 01:31 PM
Eddie07S's Avatar
Eddie07S
thanks!
Fantastic! Next mod - oil catch can.
For the stock R56 S, boost is 10 psig, over-boost is 12.5 psig. I think you won't see the over-boost during a dyno run.
madmax88
Aug 21, 2017 07:07 PM
mct
Nov 29, 2015 04:51 PM
jst_bc
Sep 11, 2015 07:45 AM
bjcarter2
Aug 31, 2015 04:03 PM
dyeLucky
Aug 7, 2015 07:10 AM
