Drivetrain Modify the lower engine mount inserts for a little less NVH?
Old Nov 2, 2012 | 08:25 AM
fishbulb's Avatar
fishbulb
I have a Powerflex lower engine mount insert like the one pictured here:
Worked great on my manual '06. Also works great on the automatic '05, but since there is no clutch to disengage the engine from trans, I get a bit too much NVH at a stop light.
I would like to get as much benefit as I can, but cut down on the rattles.
I was thinking about drilling out some material from top to bottom. I would still have the edges so it fits, but have a few holes in it like the factory one already has.
Thoughts on this, or opinions on a better way to go?
Thanks!
-Jac
Old Nov 2, 2012 | 08:48 AM
ZippyNH's Avatar
ZippyNH
Poweflex makes their products in different stiffness....the color tells you how stiff they are...
you might be able to buy the same product in a softer polly...thus making less NVH
Old Nov 2, 2012 | 05:27 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
They do NOT make those engine bushings any softer. Yellow is their softest poly.
Old Nov 2, 2012 | 08:01 PM
cristo's Avatar
cristo
Alliance Member
You can use one instead of both inserts.
Old Nov 3, 2012 | 11:01 AM
ColinGreene's Avatar
ColinGreene
or just take it out....
Or buy a Vibratechnics mount?
Old Nov 9, 2012 | 01:37 PM
andyroo's Avatar
andyroo
I was thinking about the same thing. I really like the way it feels but with the AC on it gets annoying at stoplights.
Luckily winter is coming so I won't worry about it til next spring.
Definitely interested in your results. I was thinking about trying just one of the inserts first to see if that was a good compromise, then drilling them if I wasn't happy.
- Andrew
Old Nov 9, 2012 | 02:28 PM
fishbulb's Avatar
fishbulb
I don't know enough about it to know which would be better. I think that just using one 'half' might still pass a lot of NVH, since it 100% fills the void in the factory mount - even if only on one half.
I am going to give the drill out a shot this weekend. Not sure if I will get a chance to install, but I will take pics of the modified part.
Thanks!
- Andrew
Old Nov 27, 2012 | 08:03 PM
Hooptie64's Avatar
Hooptie64
What does NVH mean/stand for?
Old Nov 28, 2012 | 04:43 AM
cristo's Avatar
cristo
Alliance Member
Noise
Vibration
Harshness
Old Nov 28, 2012 | 07:54 PM
Hooptie64's Avatar
Hooptie64
Thanks.
I have all of that with my Mini now.
Old May 7, 2013 | 01:18 PM
andyroo's Avatar
andyroo
Thanks!
Did you end up doing this?
- andy
Markbett
Jul 3, 2016 04:28 PM
silence2-38554
Nov 12, 2015 09:39 AM
minipopkart
Aug 13, 2015 05:22 AM
