Drivetrain **Q & A Thread** for Bytetronik FullAccess Tuning Kit - R50/R52/R53
Old Nov 26, 2017 | 07:01 PM
  #51
Sugeray's Avatar
Sugeray
I just watched the video that Chris Sneed made about tuning, does that mean that I have to put my Mini on a dyno?
Old Nov 26, 2017 | 09:19 PM
  #52
Hingis's Avatar
Hingis
With the bytetronik kit, no you don't need a dyno, that is up to you if you want to make a run on the dyno before your tuning/mods to check the power the car is making and then after final tune you can go back to the same dyno and check what your final power is to see your gains, but that is optional.. The bytetronik tuning process and datalogging happens on the road, no dyno at all.
Old Nov 27, 2017 | 07:55 AM
  #53
Bytetronik's Avatar
Bytetronik
No dyno is needed with our remote tuning b/c we have a the ability to data log using the MINIPort hardware module. You do need to have an Innovate Wide band installed on your car so it can log AFR readings also.
Old Mar 30, 2018 | 07:18 PM
  #54
putttn's Avatar
putttn
Still running mine up in Spokane. Runs perfect but probably needs upgrading. Is Hank still a dealer?
Old Apr 25, 2018 | 07:46 AM
  #55
Bytetronik's Avatar
Bytetronik
Yes. Hank is still a tuner/dealer for us.
Old Apr 27, 2018 | 09:29 AM
  #56
Bytetronik's Avatar
Bytetronik
FA53 Tuning Kit + 550cc Injectors
Have limited supply of the FA53 Kit with Bosch 550cc injectors = $795 plus shipping.
Old Apr 27, 2018 | 03:15 PM
  #57
downshift1's Avatar
downshift1
You have PM
Old Apr 28, 2018 | 03:52 PM
  #58
Bytetronik's Avatar
Bytetronik
DataViewer software for viewing CSV logs.
We do offer the DataViewer program to view CSV logs. Cost is $75 for FA53 customers.
Sample screen shot below:
This is how CSV logs are displayed in DataViewer software.
Old Jun 19, 2018 | 11:08 AM
  #59
midasp's Avatar
midasp
Do you still have this package deal along with the logger program available
if you still have this package deal with the logger program please email me at midasp@msn.com.
James
Old Jun 22, 2018 | 06:40 PM
  #60
midasp's Avatar
midasp
Interested in the FA53 kit
If these kits are still available I like to buy it as well as the viewer
Old Nov 12, 2018 | 08:56 PM
  #61
Bytetronik's Avatar
Bytetronik
Year End Sale is here!!!
We are currently offering two FA53 Packages for the R53:**Note: In order to subscribe to the CRM (Custom Remote Mapping) service, you must have an Innovate wide band kit installed on your car and be able to provide data-logs to us using the FA53.
Old Nov 14, 2018 | 06:48 AM
  #62
astroblackr53's Avatar
astroblackr53
Any specials for just the Injectors and CRM? I have the FA53 currently and just looking to take it to the next step.
Old Nov 14, 2018 | 07:14 AM
  #63
Bytetronik's Avatar
Bytetronik
Send us an email along with your completed CRM checklist (which can be found in the download section on our site). In order for the CRM you'll need to install the Innovate AFR kit and provide us with logs from your Mini.
Old Nov 25, 2018 | 08:47 PM
  #64
Bytetronik's Avatar
Bytetronik
Cyber Monday Special on FA53 Kits (Limted stock)!
FullAccess (FA53) Tuning Kits for the R53 are at their lowest ever. Don't miss your chance! => BUY FA53 Tuning Kit now!
Old Jan 11, 2019 | 07:43 AM
  #65
Akumazeto's Avatar
Akumazeto
Anyone else running these lately?
Old Jan 11, 2019 | 08:59 AM
  #66
BlwnAway's Avatar
BlwnAway
I am, and have been since mid 2011 or so, it's been functioning perfect, with absolutely no issues at all.
FA is what we've used to tune my turbo conversion as well, without the need to go to a stand alone ECU.
Old Jan 11, 2019 | 12:29 PM
  #67
Akumazeto's Avatar
Akumazeto
Originally Posted by BlwnAway
I am, and have been since mid 2011 or so, it's been functioning prefect, with absolutely no issues at all.
Do you know who actually tunes it via crm?
Old Jan 11, 2019 | 02:08 PM
  #68
Bytetronik's Avatar
Bytetronik
We perform the CRM
Old Jan 11, 2019 | 02:57 PM
  #69
Akumazeto's Avatar
Akumazeto
We perform the CRM
who is we that’s what I am after
Old Jan 12, 2019 | 07:07 AM
  #70
BlwnAway's Avatar
BlwnAway
Originally Posted by ThumpR52
I have an Innovative A/F gauge in preparation for FA data logging. I have noticed when lifting the throttle the AF will jump to 22.4 that according to Innovate is the same as the sensor being located outside the exhaust. Does this mean the injectors are stopped? Is this normal and it could throw a 0201 type code?
This is normal, mine does the same exact thing, with no issues or codes.
Old Jan 12, 2019 | 08:10 AM
  #71
ingsoc's Avatar
ingsoc
That is normal behavior during engine braking. It is odd that you do not know that.
Old Jan 12, 2019 | 08:33 AM
  #72
Akumazeto's Avatar
Akumazeto
Normal as engine is super lean on decel
Old Jan 12, 2019 | 09:14 AM
  #73
BlwnAway's Avatar
BlwnAway
Besides the engine being lean on deceleration due to the drop in fuel, when you let off the accelerator there's an immediate but short change in pressure in the exhaust causing a slight vacuum during transition, the gauge reads this as lean because of the lack of fuel and pressure, this is why you'll see it max out to -22.4 and then transition down as it returns to normal.
Old Feb 20, 2019 | 02:23 PM
  #74
Bytetronik's Avatar
Bytetronik
The Bytetronik Team is working hard to release a new update for FullAccess FA53 for MINI R50/R52/R53 soon in a couple of months. We are adding new maps, using the original Siemens map names and acronyms. The update will only feature Siemens VDO ECU's only at this time. From late 2005 to 2008. The older MINI vehicles will use the older map versions. Customers with older Siemens (black cover) ECU will have an option to upgrade their ECU's to the newer Siemens VDO ECUs that are used in the late 2005 to 2008 models.
The reasoning for this, the older Siemens ECU are discontinued and obsolete from BMW, and secondly the new Siemens VDO has better reworked algorithms, more 1D values, 2D tables and 3D maps for better control and mapping for those high modded and high horsepower builds using the stock ECU such as (turbo kit conversions)
Contact us for via email on our website for faster and more information.We've added a couple of screenshots for preview....
Old Feb 24, 2019 | 12:33 PM
  #75
Akumazeto's Avatar
Akumazeto
Pop, bang & flames are now available on the ... stock ECU...
