Drivetrain Loss of SOME boost while shifting
Old Jul 10, 2012 | 06:24 PM
richi0207's Avatar
richi0207
When shifting into 2nd while driving hard, my boost goes from 18 psi in 1st to 5 psi in 2nd. A few months back I installed the WMW upgrade BOV and I just re-tightened it which made no difference. I find this loss of boost happens most of the time and I am short of any ideas as I originally blamed the BOV. Any ideas? My mods are in my sig, thanks in advance.
Old Jul 10, 2012 | 06:36 PM
llewellyn's Avatar
llewellyn
I'm not sure if you can use it in the WMW BOV, but you can get a firmer spring from Alta for the factory diverter valve to hold more boost in between shifts. I don't have one, but I've been considering it.
http://www.altaperformance.com/hardt...spring-upgrade
Old Jul 10, 2012 | 11:11 PM
Sacred Disorder's Avatar
Sacred Disorder
Sounds like over loading to me (I have had the same exact issue but my car is an Auto). Is your boost creeping once you shift? It could be 18PSI then when you shift it will spike to like 22 and then the ECU cuts it down to 5. Try letting off the throttle and then going back WOT and see if it resets it. It letting off the back WOT brings the boost back it is the car overloading.
Old Jul 11, 2012 | 09:19 AM
killerfox's Avatar
killerfox
your getting a boost cut, when you hit 22psi it cuts the boost back. You might want to see if Jan can modify your tune to eliminate it.
Old Jul 11, 2012 | 06:29 PM
richi0207's Avatar
richi0207
Thanks for the replies, he mentioned it could be the new DV I installed but I'll pass by the dealer and pick one up to see if that s the culprit. It would just stay at 5 psi until I let off and get on the throttle again. It doesn't creep and I do not lose boost at higher gears. Ill try the first two things
1)boost leak? (but havent touched a boost tube in ages)
2)DV
Anyone had any similar experiences with a bad DV?
Old Jul 12, 2012 | 07:49 PM
richi0207's Avatar
richi0207
Changed the DV, its a no-go =( So it definitely is a boost cut? How did you guys get around it?
Old Jul 12, 2012 | 11:41 PM
Sacred Disorder
Your tune will have to be adjusted. Get with Jan and see if he can make some adjustments. If you have the ability to take some Data logs and send them to him that usually helps.
Rainforest_Elf
Sep 15, 2015 12:11 PM
paul7878
Sep 14, 2015 07:44 AM
CandorLush
Sep 13, 2015 06:42 PM
mbatech
Sep 10, 2015 03:40 PM
Sep 2, 2015 11:15 AM
