Drivetrain Best CAI
Old Jun 25, 2012 | 06:15 PM
  #26
RobMuntean's Avatar
RobMuntean
That is my DDM street intake which isn't a bad price at $200 and easy set up too. I average 1.5 mpg better with this setup. I went back and forth on DoS and this one but love it. None of them are bad though, so good luck in your search.
Also...I'd recommend that since our intake is all the way back of the engine that you take off your scoop grille and paint it black or use plasti dip to cover the underneath part of the scoop. It will help the car breathe A LOT better.
Old Jul 5, 2012 | 12:20 PM
  #27
Classic_Engr's Avatar
Classic_Engr
Originally Posted by rum4
Looks like a good company but they don't list the MINI as an option in their search section....
Umm, of course they do. It's listed from 2007-2010. They sell the product, why wouldn't they list it?
http://www.aemintakes.com/search/aem...nlMlYIjlAeeSGa
Which lead me to:
http://www.aemintakes.com/search/pro...x?Prod=21-699C
I know because I keep clicking on their page. Just waiting til the end of the month to pull the trigger. Maybe you have another year vehicle?
Old Jul 5, 2012 | 12:33 PM
  #28
Classic_Engr
Originally Posted by NewCooperFanatic
IMHO, CAI's are truly a waste of money...the stock assembly IS a cold air intake. Anything that is an open element is subject to heat soak and will only decrease performance.
If you want the sound, an open filter is for you, if you are putting performance ahead of everything, I'd suggest a FMIC. The price of some of these hot air filters is just ludicrous. I use a K&N drop in filter just so I could save money instead of buying paper filters. Picked up 2 MPG which is a plus.
Intake temps are either at ambient or +5. When heat soak sets, recovery time is fast...temps plummet, open filter never truly recover from this. I've played around with this using a scangauge. Numbers bested all the open filters hands down.
IMO stock is best, spend your money on something worthwhile,
But at the end of the day it's your decision
In general I agree with you. Open element intake = hot air intake. But I think the sealed systems out there may have some merit. That's what I'm researching...
Old Jul 5, 2012 | 12:41 PM
  #29
Classic_Engr
Originally Posted by Porthos
There is no true cold air intake for the R56 and the stock is surely not a CAI by any stretch. It might be a fresh air but not a CAI. If you want a true CAI it needs to be either out of the engine bay or more insulated than the stock box. Plus like stated by Hyland if you want colder temps in you intake charge get a larger inter cooler that is where it is at.
That's what I said about 3 months ago, until I saw this post by laforze:
https://www.northamericanmotoring.co...2-post112.html
And this:
http://www.aemintakes.com/dynocharts...1-699-AITS.pdf
laforze seems to have a lot of info on it, and it looks like they did their homework. This seems to qualify as a "true cold air intake" by your definition. Still doing research on DDM and all the others though...
Old Jul 5, 2012 | 01:42 PM
  #30
k_h_d's Avatar
k_h_d
On the AEM intake what is the tube on the bottom of the intake?
Old Jul 5, 2012 | 09:13 PM
  #31
LarriB's Avatar
LarriB
I just installed the DoS intake and it makes a noticeable difference in power (butt dyno). When I first installed it, I forgot to put it in Sport, and thought the intake didn't add much power. So without the Sport on, it was making similar power to the original setup in Sport. With Sport, the difference is significant.
YMMV
Old Jul 6, 2012 | 05:36 AM
  #32
rum4's Avatar
rum4
Which lead me to:
Yea I have 2012 that is the issue!
Old Jul 7, 2012 | 04:18 PM
  #33
Hujan's Avatar
Hujan
Originally Posted by JPMM
my butt dyno says the DOS does not perform as well as the stage one JCW (cone filter type, more of a cylinder shaped thing really )
Can you elaborate? I am trying to decide between the impending DoS intake (for the R60) or a JCW Stage 1 air box (which, according to Way, should fit the R60 with a touch of creativity).
Also, for those of you with the JCW Stage One, what size and type of dry filters are you using?
Old Jul 7, 2012 | 05:07 PM
  #34
JPMM's Avatar
JPMM
no science just a butt dyno feeling, so take it for what thats worth I use a OEM JCW filter in mine. If you want sound go for the DOS.
Old Jul 7, 2012 | 05:16 PM
  #35
Hujan's Avatar
Hujan
Thanks, JPMM. Actually, I'd probably tend towards less sound. I like the idea of having a quieter more subtle car. Not into loud exhausts or intakes.
Mostly interested in a little MPG gains. I've heard a lot of people say they picked up ~2 mpg by moving to an aftermarket intake. (Usually, DoS.)
Old Jul 7, 2012 | 05:23 PM
  #36
JPMM's Avatar
JPMM
they could have ,I'm comparing the DOS to a stage one JCW
Old Jul 7, 2012 | 05:26 PM
  #37
Hujan's Avatar
Hujan
Understood. Did you see any MPG differences between the two? (Or between either/both and the stock setup?)
Old Jul 12, 2012 | 10:53 AM
  #38
Classic_Engr
According to laforze's post, it connects to the stock intake tube.
Pker
Apr 11, 2017 12:14 AM
slash695
Apr 26, 2016 06:27 AM
simo711
Oct 8, 2015 07:07 PM
pglgp1292
GP Talk (2006)
Oct 2, 2015 10:34 AM
thebombardier
Sep 15, 2015 02:53 PM
