Drivetrain What's next? Throttle body?
Old Mar 12, 2004 | 08:06 AM
  #26
MSFITOY's Avatar
MSFITOY
Hey Andy, where did you tap the boost guauge into? I can barely see the short tube coming out of the bypass valve. Seems too short to connect a T.
Thanks.
Old Mar 12, 2004 | 11:15 AM
  #27
andy@ross-tech.com's Avatar
andy@ross-tech.com
I pulled the rubber hose off this nipple and installed a tee and a short piece of vacuum hose:
Old Mar 12, 2004 | 09:51 PM
  #28
dcsmd007's Avatar
dcsmd007
Coordinator :: PDX MINI
That's where I added the T fitting as well. Some people tee off the other end, from the fuel pressure regulator. :smile:
Old Mar 13, 2004 | 11:22 AM
  #29
jlm's Avatar
jlm
a tid-bit for those considering ditching the blower (and it's attached water pump) and going turbo with a non-S pump:
that little aluminum diamond plate attached to the block is where the non-S cooper's water pump fits, such pump to be belt driven. There is another port just like it near the rear for the S water pump, blower driven
bahman
Feb 14, 2016 10:29 AM
wildwestrider
11
Jan 29, 2016 05:06 PM
Qik420
Oct 4, 2015 08:19 PM
Qik420
Oct 1, 2015 12:02 PM
Emnotek
Sep 29, 2015 07:37 AM
