Drivetrain Replacement filter for Alta Intake
Old Mar 5, 2004 | 12:19 PM
cfoley's Avatar
cfoley
As I was checking my oil today I noticed the filter slightly cocked on my Alta intake. Upon further inspection I realized that the clamp had split the rubber on the neck of the filter. When I installed it in Dec 03 I was careful not to over tighten and the same thing last moth when I had it off to install my pulley. Has anyone else had this happen? Does anyone know of a paper filter element that will fit the Alta intake box? Looks like about 2 3/4" wide. Any suggestions would be greatly appreciated.
Thanks,
Craig
Old Mar 5, 2004 | 12:25 PM
andy@ross-tech.com's Avatar
andy@ross-tech.com
Old Mar 5, 2004 | 12:28 PM
minifletch's Avatar
minifletch
Craig, I believe it is 2-1/2" ID. I have researched a number on a K&N that should fit well. Not sure if that is what you are after, the K&N is a gauze filter. As soon as I receive my filter and fit it, I can post the results.
I hope that helps
Old Mar 5, 2004 | 12:31 PM
andy@ross-tech.com
K&N part number RU-1520
http://www.knfilters.com/universal/univovalstr.htm
Old Mar 5, 2004 | 12:32 PM
minifletch's Avatar
minifletch
Andy's set up looks real nice as well and this is a K&N also. When my set up is complete I will hope to have reinstalled the partition (quieter) but still pull air in from the front of the filter and cowl area.
Old Mar 5, 2004 | 12:37 PM
andy@ross-tech.com
Here are the Alta filter dimensions:
Filter Dimensions
Overall Height = 9.75" 248mm
Overall Diameter = 5.875" 150mm
Neck OD = 3.125" 79mm
Neck ID = 2.625" 67mm
Neck height = 1.75" 44mm
Pod height = 8" 200mm
Old Mar 5, 2004 | 01:16 PM
cfoley's Avatar
cfoley
Andy & Fletch,
Thanks so much, I really appreciate all the input. Andy I just ordered that RU-1520 I'm sure it'll work great, should be here by Wed next wk. Is there anything I need to do to that filter before installing it. ie: oiling it or anything else.
Thanks again, you guys are life savers. Hope I can return the favor someday!!
Craig
Old Mar 5, 2004 | 05:08 PM
andy@ross-tech.com
I'm pretty sure that K&N filters are ready to go out-of-the-box. Check with K&N, but I think the oil is only needed for cleaning.
Old May 22, 2005 | 07:12 PM
BlueCooperS's Avatar
BlueCooperS
Thanks,
Craig
I had one put on at the Dragon this year, and that's exactly what happened to it that very day.
Old May 23, 2005 | 07:38 AM
flyboy2160's Avatar
flyboy2160
check with baldwin filters. they may have a true paper element that will fit as an alternative to the oiled cotton K&N already mentioned (which i don't care for).
Old May 23, 2005 | 08:07 AM
Bahamabart's Avatar
Bahamabart
TGI Filters
check out the TGI filters (foam)
Old May 25, 2005 | 03:27 PM
ALTA2's Avatar
ALTA2
Manufacturer
If your filters base had ripped we will replace it! No matter what this isn't a normal thing that occures so don't just brush it off and buy another filter. Plus our foam filters are far superior to the K&N in cleaning and flow when dirty. Please call us and we will get one out to you right away!
Old May 25, 2005 | 06:26 PM
jbsf3's Avatar
jbsf3
I had the same thing happen to my Ata CAI. I called ALTA and they sent me a new filter, I had to send my old one in and as soon as they get the old one they will issue me a refund for the new one they sent- pretty decent service.
Old May 25, 2005 | 06:30 PM
BlueCooperS
I was lucky it happened right away. Waylen pulled a filter out of another kit. Bad luck for Waylen though, one less kit he could install.
The replacement had a couple little bubbles in the plastic at the edge, but nothing structural that I could see. It's "still ticking" but I check it FREQUENTLY now.
Old Aug 12, 2018 | 07:28 PM
Grey Lightning's Avatar
Grey Lightning
So I might win an award for resurrecting a 13 year old thread, but does anybody have any input on swapping the k&n filter onto the Alta intake like this? I like the look of this k&n and my foam filter is about done.
silence2-38554
98
Sep 21, 2016 02:52 PM
AWOL
Mar 28, 2016 10:51 AM
tr3y003
Oct 22, 2015 10:48 AM
stierzy34
Sep 15, 2015 04:40 PM
jrezzo
Aug 9, 2015 10:32 PM
