Drivetrain Upgraded cam, now car will not start at all
Old Mar 28, 2012 | 04:18 AM
  #76
niquemarshall's Avatar
niquemarshall
Originally Posted by Gamm
Thanks for the good laugh!
Back on topic...
At this stage, I wouldn't worry too much. Re-timing the engine might solve everything. Good luck!
Good laugh?
Old Mar 28, 2012 | 04:36 AM
  #77
niquemarshall
Originally Posted by mmaigret
If the timing is off, a compression test doesn't necessarily tell you much. Zero compression doesn't mean the valves are bent. It could simply be they are opening too early.
My advice would be to pull the timing cover, re-time the engine, and then check compression once timing is verified. Alternatively, you could pull the head and check the valves, but that seems like more work. Besides, if the valves look good you'll need to re-time regardless.
I had the timing pretty far off on my R53 and did not bend any valves. I have heard R50's are less forgiving due to higher compression ratio.
Yea that's the same thing the hobby shop told me after we first had issues, back on Sunday.. He said he knew for sure timing was just off
Old Mar 28, 2012 | 07:43 AM
  #78
miles_miles7's Avatar
miles_miles7
do you think the mechanic will have diagnosis of this problem by close of business day today?
Old Mar 28, 2012 | 08:40 AM
  #79
niquemarshall
Hopefully so that's what I'm expecting I'll stop by later on
Old Mar 29, 2012 | 12:00 AM
  #80
Gamm's Avatar
Gamm
Originally Posted by niquemarshall
Good laugh?
After reading the whole thread, I'm sure you will not have cracked a piston by turning the engine by hand, regardless of what Dustin at Autoxcooper said.
Old Mar 29, 2012 | 08:18 AM
  #81
niquemarshall
I would hope not
Old Mar 29, 2012 | 08:50 AM
  #82
SneedSpeed's Avatar
SneedSpeed
Never seen a piston crack by hitting the valves, even at race speed when someone money shifted an engine.
Old Mar 29, 2012 | 08:52 AM
  #83
niquemarshall
Oh ok lol that's comforting.. Still no word on the cars progress.. Mechanic doesn't seem too friendly
Old Mar 30, 2012 | 11:22 AM
  #84
niquemarshall
Mech called, he will now set timing and re run compression test
Old Mar 31, 2012 | 11:15 AM
  #85
niquemarshall
Update
IT RUNS
Old Mar 31, 2012 | 11:30 AM
  #86
niquemarshall
Timing was 90 degrees off
Old Mar 31, 2012 | 11:31 AM
  #87
BlwnAway's Avatar
BlwnAway
Cool!
Old Mar 31, 2012 | 11:49 AM
  #88
ACallahan's Avatar
ACallahan
Cool, if you dont mind me asking, what did the mechanic charge you for that "fix".
Old Mar 31, 2012 | 12:11 PM
  #89
niquemarshall
387 dollars
Old Mar 31, 2012 | 12:32 PM
  #90
ZippyNH's Avatar
ZippyNH
Sounds like life is good!!!
Old Mar 31, 2012 | 12:42 PM
  #91
niquemarshall
Yea the car def feels different
Old Mar 31, 2012 | 12:46 PM
  #92
miniblucabrio's Avatar
miniblucabrio
Glad to hear it man!
Old Mar 31, 2012 | 01:00 PM
  #93
niquemarshall
Also the pop and burble went away :(
Old Mar 31, 2012 | 01:17 PM
  #94
ZippyNH's Avatar
ZippyNH
Running a cam (no tune) is making the car run a bit leaner....so the extra fuel that is used to make the sound is now getting burnt to make more power!!
Old Mar 31, 2012 | 02:16 PM
  #95
Professor's Avatar
Professor
Odd my NS1 added loads more burble.
Old Mar 31, 2012 | 02:21 PM
  #96
niquemarshall
Well now it seems the burble is slowly coming back, however still not nearly as much as when i first added the headers
Old Mar 31, 2012 | 07:12 PM
  #97
BlwnAway's Avatar
BlwnAway
You'll have to give it a few days for the adaptations to set in, it may all come back, just depends how the ecu adjusts itself.
Old Mar 31, 2012 | 07:14 PM
  #98
niquemarshall
Yea it seems to be adjusting since the power is really coming on now
Old Apr 2, 2012 | 01:37 AM
  #99
Gamm's Avatar
Gamm
Back on topic...
Knew it had to be re-timed!
Glad it all worked out well for you!
Old Apr 13, 2012 | 08:41 PM
  #100
miles_miles7
so who said the piston is cracked?!!!
