Drivetrain Silicone intercooler boots diameter?
Old Nov 24, 2011 | 06:52 AM
Applesauce's Avatar
Applesauce
These things are round before they go onto the horns. Anyone have a nominal diameter for a new set? Thanks!
Old Nov 24, 2011 | 07:43 AM
JCWSLAYER's Avatar
JCWSLAYER
Dont know the diameter but I do know they are a tight fit and just south of a pain in the a$$ to put on.
Old Nov 24, 2011 | 08:44 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
And they crack substancially from the inside out hindering early detection of potential leaks.
After the third set of perty ones I gave up and bought new stock couplers....
Old Nov 24, 2011 | 09:10 AM
checkers's Avatar
checkers
I've used a couple different places ( Mini Madness, GT Tuning ) and did not have a problem. Yes a little hard at first to get on, but no leaks besides I like red.
Old Nov 24, 2011 | 01:28 PM
Applesauce's Avatar
Applesauce
I've heard very mixed reviews... Thought I'd do it on the cheap with higher quality round fittings (although I imagine the Altas, etc., are probably rebranded Samcos) for less money, rather than forking over for the overpriced Mini-specific items. Besides, I can get good standard round fittings in town here for a good price; the Mini ones I would have to order.
Old Nov 24, 2011 | 05:25 PM
checkers's Avatar
checkers
Cheap is great, but if they leak you could be wasting your money and time. They need to fit tight.
Old Nov 24, 2011 | 07:37 PM
Longboard110's Avatar
Longboard110
The alta couplers are way over priced. If you can find the correct size there should be no problem
Old Nov 24, 2011 | 08:01 PM
89AKurt's Avatar
89AKurt
My 2 cents, I had silicon hoses tear, no reinforcing at all. Took to auto parts store, got regular radiator hoses cut to length, worked fine.
But if want the pimped look, disregard.
Old Nov 25, 2011 | 04:19 PM
KeithGT's Avatar
KeithGT
How did you use radiator hose?
Old Nov 25, 2011 | 06:32 PM
Applesauce's Avatar
Applesauce
Maybe I'll just measure the horns, assume they're actual ellipses, and do a little experimenting... Thanks all!
ps. The fittings I'm looking at are Vibrant items, and are highly reinforced.
Old Dec 2, 2011 | 01:58 PM
ProjectSR53's Avatar
ProjectSR53
Checkers.. nice looking engine bay. Awesome on the polishing of aluminim. Did you actually do them yourself? Is that a DDM airbox? If so, how do you like it? Performance? Sound? etc. Thanks
Old Dec 5, 2011 | 03:17 PM
checkers's Avatar
checkers
Thanks and no I have it done once a year. The air box is from Craven and you can't tell but it's black chromed. The sound is great but I did replace the filter with one I had.
Old Jan 21, 2012 | 05:00 PM
dynasty_v6's Avatar
dynasty_v6
wrap a piece of string around the horn, measure the length of the string. that is the inside circumference of the hose you will need
set that # = to pi(diameter)
So, basically divide the number by pi (3.14) and there's your diameter...
IQRaceworks
53
Jun 28, 2024 07:29 AM
gar56
Nov 15, 2016 06:41 AM
shadtree
Cooper (non S)
Sep 8, 2016 12:02 PM
jennster
Sep 28, 2015 06:19 PM
Adam Bradbury
Sep 28, 2015 04:15 PM
