Drivetrain Which is better ... K&n filter or a foam filter ??
Old Sep 29, 2011 | 04:38 PM
LAMARR -s53's Avatar
LAMARR -s53
I had a k&n drop in filter for my mcs . Didn't really see and gain well came with car , plus I wanted to be able to hear the s/c alot more ( I lobe the whine ) or I did a foam style cone for a cai !! I think it works alot better plus it is alot louder now
Just wondering what is the best style of filters for are cars , sometimes I see a foam filter on turbos and sc cars , then I see a k&n style soo what's the difference if there is ????
Old Sep 29, 2011 | 08:30 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
For one thing, a properly oiled foam filter actually filters.
In mechanic's world, K&N are called "dirt suckers."
However, too much oil on the foam filter is bad, as is no oil at all.
I use the stock set up. Plastic insulates heat better than the metal boxes, and direct underhood heated air is no good. Plus the OEM paper filter will keep your engine the cleanest.
Old Sep 29, 2011 | 08:32 PM
Baker555's Avatar
Baker555
On Alta's website they have a pretty detailed review of foam filters vs. Panel type filters. From what I understand they both do a great job getting the air in when clean, but a foam filter performs better when dirty compared to a K&N type. I recommend reading the whole thing on they're website. It's pretty interesting.
Old Sep 29, 2011 | 09:08 PM
LAMARR -s53
That's cool u look at that thx
I still have my stock airbox In the car , I just took off the lid and the foam cone fit right in there. Pic shown below
Old Sep 30, 2011 | 04:29 AM
foster2's Avatar
foster2
i put the k and n into my r57 a year after i bought it. big noticable difference! should have put the k and n in on day 1 and enjoyed it.
Old Sep 30, 2011 | 05:49 AM
rod from maryland's Avatar
rod from maryland
having alot of motorcycle experiences over the years, ive seen a number of motors that were worn out...about half the cases had a k and n or similar filter... in those applications, a clean and properly oiled filter MAY have saved the rings and valves from dirt/water/ etc
but, just like any discussion, there are success and failure stories. Many people swear by their k and n types...but im sure some have sweared AT them as well .
personally, I'll take the extra work to clean and oil my foam filter. Having an extra one for the mini, just like I do for my bikes, allows for a quick swap and do the maintanence later . Somehow makes ME feel better
Old Oct 9, 2011 | 08:34 PM
minikania's Avatar
minikania
one reason why you should stay away from oil is because it throws off your map sensor.. now i'm with the k and n filter
Old Oct 10, 2011 | 02:46 PM
ggcadc's Avatar
ggcadc
the stock paper filter out performs all other element types in flow and filtering every time... this is a bit of a moot discussion as there is TONS of research out there on the differences of element types and even between brands.
also, you get more oil on your map sensor from the crank vent, a properly oiled foam element wont foul anything.
Filmy
15
Jun 6, 2023 06:27 AM
R3411y
Nov 23, 2015 01:10 PM
Sep 18, 2015 02:44 PM
Ryephile
Detailing 101
Sep 16, 2015 06:32 AM
Sep 10, 2015 11:55 AM
