Drivetrain Intercooler ???
Old Jun 20, 2012 | 04:45 PM
  #101
czar's Avatar
czar
Originally Posted by jomama
i'm curious as to why there would be a pressure fault. is it b/c of the change in the volume of the fmic? it'd be surprising to me if the pressure change as a result of the volume would register.
Anytime you change the air mass volume within the air intake circuit, you change the air volume pressure, this change is detected by the temperature/pressure sensor registering a charge air pressure fault with the ECU.
Old Jun 20, 2012 | 05:25 PM
  #102
tominizer's Avatar
tominizer
AND most likely you will be bending over to pick up the soap as they say with engine problems and Mini. They are a touchy bunch with regards to aftermarket modifications.
Czar, I dropped you an email.
Old Jun 20, 2012 | 05:50 PM
  #103
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Originally Posted by czar
All the aftermarket intercoolers log a code in the ECU, this is not a code that will be detected by your OBD II reader, but it is logged and stored in the ECU as a charge air pressure fault, if for any reason your engine was to become troublesome, and BMW MINI read this stored/logged charge air pressure fault, you could have a very hard time trying to convince BMW MINI that your engine trouble is not linked to the change in the charge air pressure!
Sorry but that is NOT true. I have the MINI software, and a Friend at the dealer and personally have installed about 30 Forge FMIC's and never seen a pressure fault caused by the intercooler.
I have seen that fault for a bad turbo, or diverter valve but never an IC.
Old Jun 21, 2012 | 12:43 AM
  #104
czar's Avatar
czar
We could argue this all day, it matters not how many intercoolers you have installed, or anyone else for that matter, nor whatever software you have personally, so on this one we will have to agree to disagree.
Old Jun 21, 2012 | 08:22 AM
  #105
DneprDave's Avatar
DneprDave
What does matter, then?
Dave
Old Jun 21, 2012 | 08:41 AM
  #106
Raymazing's Avatar
Raymazing
Dont argue CZAR will $4!+ on your argument LOL!!!
IQRaceworks
53
Jun 28, 2024 07:29 AM
gar56
Nov 15, 2016 06:41 AM
Qik420
Oct 4, 2015 08:19 PM
Qik420
Oct 1, 2015 12:02 PM
Adam Bradbury
Sep 28, 2015 04:15 PM
