Drivetrain Dyno Help
Old Jan 20, 2004 | 02:49 PM
hondacivic's Avatar
hondacivic
Hey, What gear should i run my MC in to perform a Dyno run on my PDA-Dyno?
thanks
Old Jan 20, 2004 | 04:36 PM
05JCWS's Avatar
05JCWS
I have typically heard third or fourth gear for the Mini Cooper.
Old Jan 20, 2004 | 08:53 PM
hondacivic's Avatar
hondacivic
Wow? not first?
Old Jan 20, 2004 | 09:34 PM
Ryephile's Avatar
Ryephile
You want to do your dyno runs at or near the transmission's 1:1 ratio, which for the Cooper and Cooper S is 4th. This is standard practice in the chassis dyno world. If you do your run at the lower gear, you’ll end up not loading the engine fully, and get erroneous (and low) readings.
Cheers,
Ryan
Old Jan 20, 2004 | 09:42 PM
hondacivic's Avatar
hondacivic
>>Cheers,
>>Ryan
I;m geting Nology's PDA-Dyno and it says to get the car moving at a slow rpm, so should i put it in first then get it moving, then clutch it put it in 4th? is that gonna hurt anything to make a jump in gears like that? and then it says to WOT it.
thanks
Old Jan 21, 2004 | 12:29 AM
weaverpsu's Avatar
weaverpsu
i think they thought you were talking about a regular dyno, not a portable one. Do what the directions tell you to do. someone else will answer im sure.
Old Jan 21, 2004 | 03:12 PM
hondacivic's Avatar
hondacivic
lol
ok
NYMADMINI
Dec 14, 2016 02:33 PM
slash695
Apr 26, 2016 06:27 AM
USA-RET
Nov 9, 2015 07:27 PM
eMINI of the State
Oct 2, 2015 03:12 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
