Drivetrain Dinan intake install template?
Old Apr 11, 2011 | 04:50 PM
TaylorL99's Avatar
TaylorL99
Does anyone have the printout template used for cutting the plastic when installing the dinan intake?
Old Apr 12, 2011 | 06:04 AM
myles2go's Avatar
myles2go
I thought I had saved that after doing my install, but I could not find it.
Old Apr 12, 2011 | 09:01 AM
TaylorL99's Avatar
TaylorL99
anyone have it?
Old Apr 12, 2011 | 12:19 PM
Madgepetto's Avatar
Madgepetto
Pretty sure i still have it
Let me have a look see and I will scan it if I saved it.It's a pretty easy install.
Here it is...
Mad Gepetto
Old Apr 12, 2011 | 05:01 PM
TaylorL99's Avatar
TaylorL99
print that off and it should be the right size?
Old Apr 12, 2011 | 06:26 PM
Madgepetto's Avatar
Madgepetto
yes..scanned actual size
Howdy...yes, it should be actual size, max width across the small tabs is
5.250", I can snail mail it to you if you need..I found the instruction manual that came with the kit.
Use a drill at the corners to get a clean radius and a very sharp Ex-Acto knife will actually do a good job trimming the opening.the intake top is a tight fit, but it does work, and is very nice.Not too loud until you stick your foot in it, then a fair bit of whine.Very discreet at cruising speed, and California legal.
I actually could tell the difference once it was in, just a wee bit better response.Once the 15% pulley and plugs are back in it should be great.
Good Luck!
Mad Gepetto
gimme a call if you want the manual...530-876-9900 7-4 pst
Old Apr 12, 2011 | 07:24 PM
TaylorL99's Avatar
TaylorL99
Awesome that's a huge help! I feel like I can install it without the manual, I've installed the Alta intake before. I was going to try and find a dremel to cut the opening, but you think the exacto knife will work? Also, I don't have the rubber gasket that fits over the cut. Any suggestions?
Old Apr 12, 2011 | 07:29 PM
Scavenger's Avatar
Scavenger
The seal was made from a rubber seal strip that seems to be standard automotive weather stripping like you'd find around the door frame or trunk.
Old Apr 12, 2011 | 07:43 PM
Madgepetto's Avatar
Madgepetto
+1 on the gasket
Yeah...I am pretty sure the sealing material is generic stuff in that I don't think Dinan had it made up just for them.
Also check with marine ( boating ) supply shops and RV supply shops...many times the same rubber/metal "weather stripping' is used in different venues.Split surgical tubing might work in a pinch
I think it will whistle and draw hot air without some form of gasketing...I used some aircraft tin-snips to cut the main cross-wise cut after drilling holes at each corner.The plastic is not too tough, but the X-Acto is best for clean-up work, it won't be string enough to do the actual cutting, although scoring a line and bending would probably work.
It certainly allows more air to get to the throttle body than the stock set-up.
Just holler if you need more pictures, mine is out of the car now for other surgery, so I can take pics of the installation.
Mad Gepetto sends.
Old May 18, 2011 | 10:50 AM
TaylorL99's Avatar
TaylorL99
I got it installed, and it works perfectly. Where would the rubber seal go that I was supposed to get from Dinan?
Old May 18, 2011 | 11:49 AM
myles2go's Avatar
myles2go
The seal was an bulb seal like type 2 of the seals at the top of this linked page from McMasterCarr
http://www.mcmaster.com/#bulb-seal-w...ipping/=cd06x6
It attaches to the firewall section you cut open with the bulb between the Dinan intake and the firewall. Dinan provided these pre-cut to size. I can send a picture if you like.
Old May 18, 2011 | 11:52 AM
myles2go's Avatar
myles2go
Sorry, click on the edge-grip seal at the top of the linked page and then it is of style 2 of the edge-grip seals.
Old May 18, 2011 | 12:38 PM
TaylorL99's Avatar
TaylorL99
Thank you! There are a lot of size options for the style 2, do you know which size would be the best?
Old May 18, 2011 | 12:42 PM
myles2go's Avatar
myles2go
I'll take a look at mine and let you know what size it is.
Old May 19, 2011 | 12:30 PM
TaylorL99's Avatar
TaylorL99
any luck?
Old May 19, 2011 | 06:44 PM
myles2go's Avatar
myles2go
Sorry for the delay, I didn't have the car yesterday. After looking at my install I realized that the weatherstripping has 2 bulbs. If you go to this link: http://www.mcmaster.com/#bulb-seal-w...ipping/=cdo4od and click on adjustable edge-grip seal, it is like style 12.
Old May 20, 2011 | 09:26 AM
Eric_Rowland's Avatar
Eric_Rowland
Excellent info. Thanks!
Old Jun 1, 2011 | 08:48 PM
Duvivr6's Avatar
Duvivr6
Anyone know where I could get a copy of the instructions to intall the intake?
Old Jun 1, 2011 | 09:04 PM
Eric_Rowland
See this post.
Old Jun 3, 2011 | 10:23 AM
Duvivr6's Avatar
Duvivr6
Originally Posted by Eric_Rowland
See this post.
Old Apr 23, 2018 | 08:00 AM
Blue Milk's Avatar
Blue Milk
I think I'm beating a dead horse, but I don't see the weather strippings listed from McMaster Carr in the previous posts. Anyone have any luck finding a set that works?
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
stierzy34
Sep 15, 2015 04:40 PM
Aug 21, 2015 11:25 AM
