Drivetrain upgrading DV on 2011 MCS
Old Apr 9, 2011 | 09:46 AM
alex123's Avatar
alex123
Hi Guys,
i wanted to upgrade internals of my DV (spring + diaphragm) on my 2011 MCS with 260+HP rated one from A3 as described in a different thread
https://www.northamericanmotoring.co...heck-this.html
has anyone done this on their 2011? i already got the VW DV and was about to do an upgrade as i ran into an issue of taking OEM DV off. it seems like pre-2011 R56 allowed for easier access to DV. picture of 2011 is here. did anybody do 2011 DV upgrade yet? how did you deal with moving the rubber tubing (pardon my non-technical language here) that is blocking access to DV out of the way? thx a lot
Old Apr 10, 2011 | 04:39 PM
countryboyshane's Avatar
countryboyshane
I think most people that have done this needed to take off the coolant tubes to the fill tank to access the valve. Prepare to make a mess
Old Apr 10, 2011 | 06:42 PM
Greg Davis's Avatar
Greg Davis
Yes, the coolant overflow tank needs to be moved out of hte way. Make sure to release the pressure before you undo the hose - or you will be cleaning coolant from every little crevice in your engine compartment.
It is a true PAIN to get to, but it can be done.
Old Apr 10, 2011 | 09:32 PM
chakraj's Avatar
chakraj
What?!? Yes they have changed the set up and it looks much harder.
I have taken that stupid dv off so many times I can do it in 20 minutes now. You just move the tank to the side you don't have to disconnect it.
The reason I was taking it on and off is because I had the forge dvplate that turns it into a blow off valve. I could not make my mind up, I had it on and off every week. I eventually sold it so my knuckles could get a rest, and as soon as I did I wanted it back on, but o well.
Old Apr 10, 2011 | 10:36 PM
Melangell's Avatar
Melangell
Way will be changing mine out at The Dragon just so I don't have to mess with it!
Old Apr 11, 2011 | 06:37 AM
alex123's Avatar
alex123
thx for the info, guys!
moving the coolant tank out of the way is not a problem though moving the tubes didn't look that trivial at the first glance. i am pretty handy and should be able to manage it...
Kimolaoha
Jul 5, 2023 01:04 PM
luisfv56
Oct 1, 2015 08:57 AM
Zettinger
Aug 25, 2015 04:04 PM
massmini03
Aug 12, 2015 11:19 AM
nomar116
Aug 10, 2015 11:24 PM
